Thread: Does 1997 GTP SC have PCV o-rings ?
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I will pull it and check, I don't recall seeing the o-ring in the hole, dealer item or find one at auto parts store or Harbor Freight ?
    Does anyone recall size ?
    1997 Red GTP 182000 miles stock
  2. #22 Re: Does 1997 GTP SC have PCV o-rings ?
    I pull out my Harbor Freight o-ring kit when I need one.
  3. #23 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    DH is talking supercharged. But unless you lean over and look into the hole, you'll never see the strainer.
    You can barely see it from below as well. See the thing in the hole
    that's the strainer. Anyhow one o-ring on the bottom piece of the pcv and seal the top cover.
    ok, so only one o-ring, i notice the NA's have a black one on top of the PCV.
    Also you say seal the top cover, there is a gasket there,is that enough? or maybe a little RTV ?
    Thanks
  4. #24 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    So can one little missing o-ring in a PCV actually cause a rough idle and throw a p0171 , I guess I will find out soon.
  5. #25 Re: Does 1997 GTP SC have PCV o-rings ?
    Quote Originally Posted by GTP in RTP View Post
    Would I have told you about it if it were an optional part?
    Not having the ring can put let pressures go back and forth w/o anything stopping them. Hence the job of the positive crankcase ventilation valve.
    Since you might not believe me, but you'd believe someone that put something unchecked on the internet.. here ya go
    Crankcase ventilation system - Wikipedia, the free encyclopedia
  6. #26 Re: Does 1997 GTP SC have PCV o-rings ?
    Nov 2011
    south carolina
    It can. I would expect it.
  7. #27 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by rocknnachos View Post
    I believe you guys, not questioning your knowledge, I am just trying to learn things,
    Will try this weekend when I can get some daylight, thanks for all the help.
  1. AC Compressor O Rings Picture
    By mainecrab in forum General Tech Discussion
    Last Post: 05-22-2011, 08:02 PM
  2. Fuel Lines O rings
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-05-2010, 08:45 PM
  3. Injector 0-Rings
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2010, 08:55 AM
  4. Hubcentric rings? used for wat?
    By keredwtf in forum Tires & Wheels
    Last Post: 07-14-2009, 02:57 PM
  5. Centering Rings on my new 18's
    By cboth686 in forum Tires & Wheels
    Last Post: 05-09-2009, 12:59 AM
