Thread: loud as hell squealing sound from air vents
Results 1 to 11 of 11
  1. #1 loud as hell squealing sound from air vents
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Sometimes, not all the time, when i go to turn on the heat in my car, i get a LOUD screeching sound coming from them. Is this cause my AC compressor is bad or is something else wrong?
  2. #2 Re: loud as hell squealing sound from air vents
    St. Cloud, MN
    Blower motor?
  3. #3 Re: loud as hell squealing sound from air vents
    blower fan?
  4. #4 Re: loud as hell squealing sound from air vents
    SE Level Member ttjj1410's Avatar
    Nov 2011
    fairbanks, ak
    it is youre blower motor get a new one.
  5. #5 Re: loud as hell squealing sound from air vents
    Oct 2011
    New Jersey
    Lol great more problems that i dont have money to fix. How much will this run me?
  6. #6 Re: loud as hell squealing sound from air vents
    St. Cloud, MN
    Just get a used one. They are cheap.
  7. #7 Re: loud as hell squealing sound from air vents
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Get the same one that comes with the car. Which is delphi I believe. Seems like everything else is too loud or vibrates the dash.
  8. #8 Re: loud as hell squealing sound from air vents
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    Mine did the same thing. I actually pulled the blower motor out. Took the case apart cleaned it out and lubed the shafts with grease. It's been working great ever since. I know I'm probably on borrowed time but still it's working and only took about 15 minutes.
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  9. #9 Re: loud as hell squealing sound from air vents
    Pennsylvania
    Quote Originally Posted by Freimuth View Post
    I should do this. Aftermarket one whines a bit.
    But yeah... are you sure one of your vents isn't closed or half closed or something? Maybe clogged with air fresheners that fell in?
  10. #10 Re: loud as hell squealing sound from air vents
    I find if the vents are closed and pointed all the way down, they make a whistling noise.
    If they're closed, have them facing forward, not up or down at all.
  11. #11 Re: loud as hell squealing sound from air vents
    Oct 2011
    New Jersey
    No it isn't a whistling sound, its an intense (lightly vibrating) squeal as if somethings loose
  1. Squealing - tap shift only?
    By Godfather in forum 5.3L V8 (LS4)
    Last Post: 10-17-2011, 10:41 AM
  2. exhaust loud as hell!!
    By tmackster in forum General Tech Discussion
    Last Post: 03-27-2011, 05:46 PM
  3. Loud Metal Clanking sound
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 02:05 PM
  4. Loud "Pop sound in rear 10 seconds after car is off
    By MidnightSpecial in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2009, 07:00 AM
  5. Squealing Noise
    By eXceL(FAM) in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 07:49 PM
