Sometimes, not all the time, when i go to turn on the heat in my car, i get a LOUD screeching sound coming from them. Is this cause my AC compressor is bad or is something else wrong?
Mine did the same thing. I actually pulled the blower motor out. Took the case apart cleaned it out and lubed the shafts with grease. It's been working great ever since. I know I'm probably on borrowed time but still it's working and only took about 15 minutes.
I find if the vents are closed and pointed all the way down, they make a whistling noise.
If they're closed, have them facing forward, not up or down at all.
