Thread: hvac delete questions
Results 1 to 15 of 15
  1. #1 hvac delete questions
    SE Level Member exofis's Avatar
    Louisiana
    ok so my ac doesn't work but the heater does. and my gtp is no longer my dd so i want to try and make it track worthy. i want to delete the hvac system but i'm not sure of what all needs to be done. i would like to keep the heater if possible. any input is appreicated.
    Asshole Motorsports
    Because going fast looks much cooler when your car is on fire...
  2. #2 Re: hvac delete questions
    utah
    theres a bypass pulley on the market some wheres to run the ac delete
  3. #3 Re: hvac delete questions
    You can get a bypass pulley at autozone.
  4. #4 Re: hvac delete questions
    Bunnell, FL
    so just get pulley and rip and gut?
    i'm thinking about doing this, but then again i live in florida
    I'm a Sex Offender
  5. #5 Re: hvac delete questions
    utah
    Why would you ever conisder that in florida? Id never do it anyway unless it was a dedicated track car. Kiss the defroster good bye..and its hot. Wtf wants to be hot?
  6. #6 Re: hvac delete questions
    Louisiana
    it's going to be able to drive to the track. now back home is different story lol. anyway i know i need to delete the compressor and condenser. i know that there are more components to delete. i just need to what the components are and if there is a way to mod and keep the heater. i'm in louisiana and not a fan of the cold.
    Asshole Motorsports
  7. #7 Re: hvac delete questions
    Take out the compressor, condenser, lines, accumulator, and if you really wanted to you could take out the evaporator.
  8. #8 Re: hvac delete questions
    Bunnell, FL
    Quote Originally Posted by boostedcompg View Post
    have you priced a working condenser, compressor and evaporator lately
    I'm a Sex Offender
  9. #9 Re: hvac delete questions
    Bunnell, FL
    and i've only owned 1 vehicle where the a/c worked and it was a ram. everything else was gm
    I'm a Sex Offender
  10. #10 Re: hvac delete questions
    utah
    I've never owned a car where the ac didn't work..even my 85 200sx had a workin ac.
  11. #11 Re: hvac delete questions
    Bunnell, FL
    congratulations, would you like a cookie?
    all of the cars i've owned were gm except the one that did have a/c and it was a mopar
    I'm a Sex Offender
  12. #12 Re: hvac delete questions
    utah
    I guess I've always been a fan of fixing things that break. I know I'm weird.
  13. #13 Re: hvac delete questions
    Quote Originally Posted by z3r0 View Post
    I lucked out and my parts car i bought had working ac so i swapped everything over. Turns out my compressor was leaking.
  14. #14 Re: hvac delete questions
    Louisiana
    well in the event this was my dd i would fix it. but since it will only be driven a few months if each year and has the potential of being broken, since it is a track car, there's no point in fixing the ac! this thread was started to try and figure something out not start a poo flinging contest if someone can fix an hvac system.
    Asshole Motorsports
  15. #15 Re: hvac delete questions
    Bunnell, FL
    i actually wanna see a write up on exactly what can anways
    I'm a Sex Offender
  1. EGR delete questions....
    By gtpfergie in forum General Tech Discussion
    Last Post: 09-27-2011, 10:36 PM
  2. DIC HVAC gone..
    By Jay7199 in forum General Tech Discussion
    Last Post: 06-07-2011, 10:03 PM
  3. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  4. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  5. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
