Thread: thermostat temp sensor and interior air temp sensor failure?
Results 1 to 5 of 5
  1. #1 thermostat temp sensor and interior air temp sensor failure?
    SE Level Member lewethetiger73's Avatar
    Oct 2011
    mukwonago wi
    How often should the coolant temp sensor be replaced? It is the sensor under the t-stat. Does it fail ever? And what exactly does a air temp sensor do? Thanks
  2. #2 Re: thermostat temp sensor and interior air temp sensor failure?
    Lew.. Can you please fill us in on what year and model of car you are asking about.
    It's not super common for the ECt to fail, but it's a sensor and it can fail. There's no expected change interval. There's also no interval where you should automatically replace it.
    Air temp sensor.. well..it's in the intake. When you give us more info, we can tell you exactly where to find it.
  3. #3 Re: thermostat temp sensor and interior air temp sensor failure?
    Oct 2011
    mukwonago wi
    It is a 06 grand prix gt. I do know where it is under the t-stat, just not how often to change it or if it goes bad. Just trying to figure out this no heat issue and motor temp issue. Thanks
  4. #4 Re: thermostat temp sensor and interior air temp sensor failure?
    Well, you shouldn't need to replace the ECT...unless it's giving the dash or PCM bad info about the temp.
    The IAT merely tells the pcm what temp the air coming into the motor is, that's about it.
  5. #5 Re: thermostat temp sensor and interior air temp sensor failure?
    Nov 2011
    DFW
    Does your car have automatic climate control? If so there is an air temp sensor in from on the A/C condensor that reads outside temp and if it thinks it is hot out, no heat in auto mode.
  1. Temp sensor?
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2011, 06:53 AM
  2. Where is that Temp Sensor?!?!?
    By jammy in forum General Tech Discussion
    Last Post: 02-26-2011, 01:55 PM
  3. Temp. Sensor?
    By Peirce1970 in forum General Tech Discussion
    Last Post: 01-27-2011, 08:01 PM
  4. outside temp sensor
    By silvermistchick in forum General Tech Discussion
    Last Post: 06-16-2010, 09:25 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
