Thread: which parameters to run on aeroforce?
Results 1 to 6 of 6
  1. #1 which parameters to run on aeroforce?
    Bunnell, FL
    1. INTAKE AIR- Intake Air Temperature - **
    2. COOLANT TEMP- Engine Coolant Temperature **
    3. TRANS TEMP 1- Transmission Temperature for automatic gas vehicles
    4. TRANS TEMP 2- Trans temp for some vehicles made from ’94-’97.
    4. RPM- engine Revolutions Per Minute **
    5. MAF SENSOR LB/M- Mass Air Flow (lbs/min) **
    6. MAF FREQUENCY- raw Mass Air Flow sensor output (frequency)
    7. MAF FREQUENCY 2- raw MAF sensor output for the Cobalt SS and Redline
    8. MAP SENSOR- Manifold Air Pressure (kPa) **
    9. BOOST – Intake vacuum/boost displayed in inHg/PSI. Corrected by altitude entry or barometer**
    9. THROTTLE POS. PCT- Throttle Position percentage (0-100%)
    10. THROTTLE VOLTS- Throttle Position sensor output (0-5 volts)
    11. MILES PER HOUR- Miles Per Hour **
    12. KNOCK RETARD- Knock Retard (degrees) for most GM vehicles
    13. KNOCK RETARD 2- used for KR value of ’94-’97 LT1’s and some 96/97 V8’s.
    14. KNOCK RETARD 3- used for knock retard value of the Cobalt SS SC and Redline
    15. IGNITION ADVANCE- ignition timing advance
    16. PULSE WIDTH- injector #1 pulse width (4&6 cylinder engines)
    17. SHORT TRIM B1-short term fuel trim bank#1
    18. SHORT TRIM B2-short term fuel trim bank#2
    19. LONG TRIM B1-long term fuel trim bank#1
    20. LONG TRIM B2-long term fuel trim bank#2
    21. OXYGEN SENSOR B1-O2 bank 1 sensor 1 in millivolts
    22. OXYGEN SENSOR B2-O2 bank 2 sensor 1 in millivolts
    23. OXYGEN SENSOR – alternate O2 sensor parameter, rarely supported.
    24. RUN TIME MINS- engine run time is tenths of seconds since last engine start **
    25. BATTERY VOLTAGE- Alternator/battery output voltage **
    26. IAC POSITION- Idle Air Control counts (position of Idle Air Control valve)
    27. PULSE WIDTH B1-injector Pulse Width for bank 1 (8 cylinder engines)
    28. PULSE WIDTH B2-injector Pulse Width for bank 2 (8 cylinder engines)
    29. ENGINE LOAD- calculated Engine Load (0-100%) **
    30. ENGINE OIL PRESSURE (some 8 cylinder engines) **
    31. INTAKE AIR 2 – Intake Air Temp. downstream of intercooler (some supercharged applications such as the
    Cobalt SS, Ion Redline).
    32. TRANS TEMP AL- Allison transmission temp, Duramax and Workhorse
    33. TORQUE CONVERTER SLIP AL- Allison transmission converter slip, Duramax and Workhorse
    34. TQ TO TRANS AL- Engine torque delivered to trans, Duramax and Workhorse
    35. INJECTOR RAIL PRESSURE DESIRED DM- Duramax
    36. INJECTOR RAIL PRESSURE ACTUAL DM- Duramax
    37. THROTTLE PCT DM- Throttle percentage- Duramax
    38. THROTTLE VOLTS DM- Throttle sensor voltage- Duramax
    39. FUEL LEVEL DM- Duramax
    40. INJECTOR FLOW RATE DM- Duramax
    41. Desired Turbo Vane Position- 2004+ Duramax
    42. Actual Turbo Vane Position- 2004+ Duramax
    43. Pilot Injector Pulse Width- pilot injector pulse width in msec. - Duramax
    44. Main Injector Pulse Width- main injector pulse width in msec. - Duramax
    45. Pilot Injector Timing- in degrees - Duramax
    46. Main Injector Timing- in degrees - Duramax
    47. Pilot Injector Fuel Rate- mm^3 - Duramax
    48. Main Injector Fuel Rate- mm^3 - Duramax
    49. Miles Per Gallon 1- instantaneous fuel economy for gas vehicles
    50. Miles Per Gallon 2- instantaneous fuel economy for diesel vehicles
    51. HP 1- Calculated net horsepower for gasoline vehicles
    52. HP 2- Calculated net horsepower for diesel vehicles
    53. Analog 1 – analog input #1.
    54. Analog 2 – analog input #2
    55. TOTAL MISFIRES- Total misfires of all cylinders. Resets every minute.
    56. BAROMETRIC PRESSURE- limited support on standard GM vehicles, DM support
    57. PITCH – H2 Hummer support – indicates the angle of inclination of the vehicle.
    58. CURRENT GEAR- Current gear of the transmission
    59. TORQUE- Calculated torque from engine to transmission
    60. SHIFT TIME- time (msec) for last shift to occure.15
    61. TORQUE CONVERTER SLIP – Amount of slip allowed by torque converter
    62. TORQUE CONVERTER STATUS- Indicates whether torque converter is locked (L) or unlocked (UL)
    **These standard GM parameters also are supported by the Duramax diesel
    Bi-directional controls:
    1. Fan 1-3 control
    2. PCM (fuel trim) reset
    3. CASE (Crank Angle Sensor Error) Re- Learn
    def going to have:
    KR
    Volts
    Boost
    but what else should i run?
    97 gtp open cone intake, headers, 104's, 180
    I'm a Sex Offender
  2. #2 Re: which parameters to run on aeroforce?
    Neither of that crap...get a tune?
    And a smaller pulley?
    Then worry about scanning it?
  3. #3 Re: which parameters to run on aeroforce?
    Out West
    **** volts. If the car needs a battery, it'll let itself be known.
    I keep mine on LTFT and KR.
  4. #4 Re: which parameters to run on aeroforce?
    utah
    Iat
  5. #5 Re: which parameters to run on aeroforce?
    Topeka, KS
    I do the same thing.
    I sometimes watch my Pulse Width instead of LTFT.
    When i know my car's running right i have it on either Manifold Pressure/ KR or IGN Advance / KR.
    I like to know how things are doing when i go WOT and i like to know how high my advance is at cruise.
    It's all really dependent on what your wanting to watch. If your car is drinking gas like an alcoholic drinks his Vodka then you wanna watch the IPW ect...
    When i'm at the track i put it on Trans Temp and IAT in the pits so i can see how long i need to wait for it to cool down.
  6. #6 Re: which parameters to run on aeroforce?
    Bunnell, FL
    well paid 100 for this gauge
    so i got it alot earlier than need be
    and i'm scanning now because it's stock motor/trans/sc for 225k miles
    and after reading some more
    kr, iat, trans temp, coolant temp
    I'm a Sex Offender
  1. Aeroforce??
    By Ricky21 in forum General Tech Discussion
    Last Post: 06-03-2013, 03:41 PM
  2. scan parameters
    By sca555 in forum General Tech Discussion
    Last Post: 03-19-2011, 01:12 PM
  3. Aeroforce?
    By speedemongtp in forum General Tech Discussion
    Last Post: 11-07-2008, 07:30 PM
  4. Why cant I see parameters
    By deangtp in forum PCM Tuning
    Last Post: 04-14-2008, 06:03 PM
