Thread: Radio installation leads to bigger issues
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Radio installation leads to bigger issues
    London Ont, Canada
    dont tell him you broke it badly..
    you wanna buy the wiring harness, dash mounting kit, antenna adapter. if these thigns come with the kit WHEN YOU CHECK OUT. then youre fine... also they include install instructions. Crutchfield is boss like that
  2. #22 Re: Radio installation leads to bigger issues
    Omaha, NE
    You know that you could have hooked the amp up with the stock head unit right?
  3. #23 Re: Radio installation leads to bigger issues
    London Ont, Canada
    too late brian.. its over now lol
  4. #24 Re: Radio installation leads to bigger issues
    Nov 2011
    Omaha, NE
    ok so i wired the old harness back in and still no heat or anything. So should i turn to fuses? Which ones? I want to fix it myself otherwise I will just pay someone I know to fix it...
  5. #25 Re: Radio installation leads to bigger issues
    London Ont, Canada
    Check all them. You could have blown one. Easy fix.
  6. #26 Re: Radio installation leads to bigger issues
    Nov 2011
    Omaha, NE
    How do you hook up the amp to the stock radio? Also it was the radio battery fuse that was bad. I tried to find A stock one at the local yard with no success so I might be able to borrow a friends but he says the cd player doesnt always work so I don't know whAt to do about it
  7. #27 Re: Radio installation leads to bigger issues
    Bunnell, FL
    You NEVER cut your factory radio harness!
    unless you fix what the previous owner did and then you just run all new speaker wires amp turn on and make sure your ground and 12v+ are good
    I'm a Sex Offender
  8. #28 Re: Radio installation leads to bigger issues
    Nov 2011
    Omaha, NE
    So how do I hook up tue amp to the stock stereo and make the cd player work? I just wanna know because I want to pick it up tomorrow and work on it..
  9. #29 Re: Radio installation leads to bigger issues
    Houston
    The same way you would an amp to an aftermarket HU. The only difference is that you need line out converter(s) for the RCA signal. Or, if the amp has high level inputs on it, you can use that.
  10. #30 Re: Radio installation leads to bigger issues
    Omaha, NE
    In my opinion, The line out converters that use the rear speaker wires are the best for keeping the stock head unit.
    Should look something like this little guy
    Pac Audio SNI-50A Adjustable High Power Line Output Converter
  11. #31 Re: Radio installation leads to bigger issues
    Nov 2011
    Omaha, NE
    So with that I just have to splice right into the rear speaker wires at the head unit? Thanks for all of the info so far guys it has been great.
  12. #32 Re: Radio installation leads to bigger issues
    Houston
    Quote Originally Posted by 87IROCZOWNER69 View Post
    If you dont have bose, you can just tag the wires at the speaker. Then you dont have to run the RCA's through the entire car, its just a straight shot from your rear speakers to the amp.
  13. #33 Re: Radio installation leads to bigger issues
    Nov 2011
    Omaha, NE
    The RCAs have already been run through the car for both the speaker amp and the non existant sub so going right into the factory harness would be fine right?
  14. #34 Re: Radio installation leads to bigger issues
    Houston
    Oh...yeah that'll be fine.
  15. #35 Re: Radio installation leads to bigger issues
    Nov 2011
    Omaha, NE
    Ok so I got a new head unit and started this thread looking for help on fixing stuff...
    http://www.grandprixforums.net/speak...ues-55119.html
  1. Bigger Pulley
    By stok3z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2011, 11:03 AM
  2. New Front O2 leads to issues...
    By Mr Chill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2010, 10:40 AM
  3. how do i make my sig pic bigger?
    By nicksilvergt99 in forum Off Topic Discussion
    Last Post: 10-15-2009, 06:22 PM
  4. High Amp Alt vs. Bigger Cap
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 04-19-2009, 04:52 AM
  5. Someone that Leads by example
    Last Post: 11-22-2008, 02:23 PM
