Thread: HUD not working...
Results 1 to 11 of 11
  1. #1 HUD not working...
    Oct 2011
    Southington, CT
    So ever since I bought my GTP the HUD has not been working. When I am in park it works perfectly fine, but as soon as I start to drive it flashes turns off flashes turns off. I have no idea how to fix this or what the problem may be. Anyone with any idea please respond!!
  2. #2 Re: HUD not working...
    SE Level Member hcokiid18's Avatar
    May 2011
    Dayton, Ohio
    try replacing the current fuse its linked too, might not be the right size.
    04 GTP Comp G. 3.4'' Pulley, Pace setters, 180*STAT, Tuned,Slotted Rotors,Thrasher Intake, 152k
  3. #3 Re: HUD not working...
    Oct 2011
    Southington, CT
    where abouts would that be located?
  4. #4 Re: HUD not working...
    GT Level Member GMCustomerService's Avatar
    Michigan
    I would like to research this issue further, could you please pm me your name, VIN number and any other information regarding your problem. Has the HUD always flashed or is this a new occurrence? Does it only happen when driving? Does it continue to flash on and off or does it flash a few times then shut off? I look forward to hearing from you.
    Louis
    GM Customer Service
  5. #5 Re: HUD not working...
    SE Level Member soccerboi11's Avatar
    Oct 2011
    Virginia
    I have a similar problem exept now it just doesn't work completly will try fuses and my friend said we could swap his out to see if its the hud it sure hope not there kinda pricey.....
  6. #6 Re: HUD not working...
    Bunnell, FL
    could be the switch.
    I'm a Sex Offender
  7. #7 Re: HUD not working...
    You could try fixing the photocell in it. It's a common problem.
  8. #8 Re: HUD not working...
    utah
    the huds have a **** ton of common problems. the springs break that adjust it so it points straight up, the switchs goes bad, sometimes just the hud unit itself goes bad. start cheap (fuses) and work your way up til you find the issue
  9. #9 Re: HUD not working...
    Bunnell, FL
    ^^^ the springs don't go bad in the 97-03
    I'm a Sex Offender
  10. #10 Re: HUD not working...
    utah
    I learned something today
  11. #11 Re: HUD not working...
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    Quote Originally Posted by boostedcompg View Post
    thats sounds alot better than takin it to the stealership and having them charge out the ass to fix it. learning the problem and doing it yourself
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  1. 00 gtp hud not working
    By barnstormerjack in forum General Tech Discussion
    Last Post: 04-23-2011, 10:28 PM
  2. HUD not working
    By tdm571 in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2010, 09:05 PM
  3. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
  4. AC not working
    By thewaitinggame in forum General Tech Discussion
    Last Post: 06-29-2009, 12:15 PM
  5. A/C not working
    By NewPrixOwner666 in forum General Tech Discussion
    Last Post: 06-27-2009, 01:30 PM
