Thread: Blend Door Actuator, my own damn fault
Results 1 to 11 of 11
  1. #1 Blend Door Actuator, my own damn fault
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Ok so I took the actuators off to make sure that wasnt the heat issue. Is there a way Im susposed to reset them/put them back on? I saw them both spin a bunch then put them back on, now door wont close for the AC? I just should stop touchin ****
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Blend Door Actuator, my own damn fault
    Topeka, KS
    There's a way to re-calibrate them but i forget the sequence. Try Automotive Repair, Auto Recalls, Automotive Software & TSB's - ALLDATA
  3. #3 Re: Blend Door Actuator, my own damn fault
    the blend door wont turn?
    if its the knob, try pliers to turn it, i had to on my pass side. it was very stiff to turn on mine.
  4. #4 Re: Blend Door Actuator, my own damn fault
    Oct 2008
    IL
    No i got the door to turn by hand when i put it back together it wont turn. The actuator itself did like 3 full turns now wont work. Seems like theres gotta be a way to re calculate. Alldata didnt show much
  5. #5 Re: Blend Door Actuator, my own damn fault
    Pennsylvania
    Doesn't it do a reset when you plug it in?
  6. #6 Re: Blend Door Actuator, my own damn fault
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    unplug the battery for 15 minutes then it should do it recalibration. that or pull a certain fuse.
  7. #7 Re: Blend Door Actuator, my own damn fault
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    If I understand what you're saying, you're talking about the mechanical connection from the actuator to the door lever. Just determine what direction it operates and what the position should be by comparing the two from side to side. With it plugged in, but still not connected, mechanically, you can operate it using your HVAC control and put the rotor portion in the correct position.
    No worries - just take a break for a bit and look at what is happening with the door, then at what happens with the actuator when operated and bolted in position. You'll get it.
  8. #8 Re: Blend Door Actuator, my own damn fault
    Oct 2008
    IL
    Quote Originally Posted by SlowNA06 View Post
    Never actually unplugged it. Just was checking if they worked.
    Quote Originally Posted by Grimsin View Post
    Ill give this a shot tonight.
    Quote Originally Posted by SnowDrift View Post
    Yea thats pretty much what Im saying. I tried this and it didnt work but everything worked just fine before hand. I had it off the door lever and after it spin however many times i could hit whatever button and wouldnt do much. Seems wierd I know they work just now its getting odd.
  9. #9 Re: Blend Door Actuator, my own damn fault
    Apr 2009
    Did it work out for you?
  10. #10 Re: Blend Door Actuator, my own damn fault
    Oct 2008
    IL
    No its wierd I know the actuators work I watched them. I just think it may need to be reset now because if I hit the ac button(snowflake) it doesnt move. I know the cause of no heat is the heater core clogged but this is just from me messin with it i think
  11. #11 Re: Blend Door Actuator, my own damn fault
    St Thomas Ontario
    My blend door motor went bad on the driver side, so unplugged the battery, replaced the motor($60), plug battery in. start car with fans off, listen to blend door motor recalibrate(60 seconds DONT turn fan on) then turn the fan on crank the heat and it worked!
    if you havent unplugged your batt to let it recalibrate then thats probably your issue
  1. Blend Door Actuator Replacement
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2017, 04:59 AM
  2. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  3. Blend door or actuator?
    By EJOUIE in forum General Tech Discussion
    Last Post: 05-05-2013, 11:00 PM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
