Thread: 2000 GTP - Part # for throttle body to EVAP hoses (flex)?
Results 1 to 5 of 5
  1. #1 2000 GTP - Part # for throttle body to EVAP hoses (flex)?
    Jul 2010
    Warrington, PA
    I'm looking for a part # (Dorman, Delco, etc...)
    I have a 2000 GTP and I hope I just discovered the source of my P0440 code.
    There's a hose which comes off of the throttle body, it starts off pretty fat then reduces, and curves, then plugs into a hard plastic line which extends over the intake, then there's another flex hose which does a 180 degree bend into an evap thingie.
    Both my hoses were desintigrated. I rigged something for now but I'd like the right ones.
    thanks for any leads.
    -Dan
  2. #2 Re: 2000 GTP - Part # for throttle body to EVAP hoses (flex)?
    Sounds like the TB to evap soleniod hose.
    Someone should have the diagram
  3. #3 Re: 2000 GTP - Part # for throttle body to EVAP hoses (flex)?
    Jul 2010
    Warrington, PA
    found this thread with one of the part numbers
    24506665
    http://www.grandprixforums.net/gm-pa...hose-3798.html
    If I can find the other # I will order then both.
  4. #4 Re: 2000 GTP - Part # for throttle body to EVAP hoses (flex)?
    Apr 2011
    Athens, AL
    You can get it at the dealer and it's easier to see it on the diagram that they have. You will not find this part anywhere except made by ac delco so it is overpriced. I think I paid like $30 for this little thing. I'm not sure of the part number for it though. Mine was ripped where it connected to the throttle body and was really loose from age where the rubber connected to the plastic connector that attached to the evap.
  5. #5 Re: 2000 GTP - Part # for throttle body to EVAP hoses (flex)?
    SE Level Member tcafego's Avatar
    Aug 2011
    taylor, mi
    $15 at the dealer is what mine costed me. It tore right where it comes off the throttle body. Easy to install too. Just tell them and they'll give u a diagram so you can just point out the hose
  1. 2000 Grand Prix 3800 Part Throttle SURGE trans???
    By rschap1 in forum General Tech Discussion
    Last Post: 12-04-2011, 06:36 PM
  2. What is the name of the part the heater core hoses hook into?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2011, 04:28 PM
  3. vid shot of my car going part throttle boost
    By fst in forum Track Sessions and Kills
    Last Post: 09-08-2011, 10:51 AM
  4. Misses and KR at part throttle, oh and low compression on six
    By matt5112 in forum General Tech Discussion
    Last Post: 09-15-2010, 12:43 PM
  5. part throttle kr
    By Sabrewings in forum PCM Tuning
    Last Post: 06-09-2008, 09:30 PM
