Thread: Starting Problem
Results 1 to 8 of 8
  1. #1 Starting Problem
    Oct 2011
    Chicago
    Car was struggling to start after being driven, then after starting for a sec would die. Battery is good, and there is spark. MAF was replaced a couple months ago. Im thinking fuel filter? Ideas?
  2. #2 Re: Starting Problem
    What kinda car you got? year, make, model.
  3. #3 Re: Starting Problem
    Unplug the maf and double check it. I wouldn't shotgun a filter unless you know it's been neglected. Then I'd do it and test fuel pressure.
  4. #4 Re: Starting Problem
    Oct 2011
    Chicago
    its a 2000 gtp
  5. #5 Re: Starting Problem
    Oct 2011
    Chicago
    the car did start fine after sitting for an hour
  6. #6 Re: Starting Problem
    Means nothing to us.
  7. #7 Re: Starting Problem
    Oct 2011
    Chicago
    I meant fuel pump btw, wasn't hearing it prime when car wasn't starting
  8. #8 Re: Starting Problem
    Fuel pump will prime if the resistor is bad.
    I'd bend the pin on the fuel pump speed resistor (85 or 86) and give that a try.
  1. Problem with starting sometimes and hesitation with wot
    By seanparker3 in forum General Tech Discussion
    Last Post: 04-28-2011, 01:49 PM
  2. Starting Problem
    By bradycat101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 03:17 PM
  3. Starting Problem
    By SHayes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 02:49 PM
  4. Starting problem....
    By greatAEorion in forum General Tech Discussion
    Last Post: 09-30-2009, 09:54 AM
  5. 06 GT SC starting problem
    By BHMJohn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2009, 11:38 PM
