Thread: ARP Header bolts
Results 1 to 10 of 10
  1. #1 ARP Header bolts
    Barksdale AFB, LA
    When using these bolts, what happens to the items that use the exhaust studs and a nut? I can think of three...
    1. Engine lift bracket (sure, it can be removed and isn't needed for daily driving).
    2. Oil dipstick bracket.
    3. L36 passenger side mount bracket.
    2009 Subaru Impreza WRX STI
  2. #2 Re: ARP Header bolts
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    I only use the 1 stock bolt for the oil dip stick.
    A little tip, I ALWAYS start installing the headers with a stock stud to hold the gasket in the right place. Once a couple bolts are in, I then remove the stud and replace it with a bolt.
  3. #3 Re: ARP Header bolts
    Barksdale AFB, LA
    What about the passenger side brace? I know the L67 doesn't have it, so you may not be able to visualize:
    See the black bracket coming off the #1 primary?
    I've seen where L36 guys left it off and ended up cracking the upper portion of the passenger side mount. Especially if you have poly bushings (like I do).
  4. #4 Re: ARP Header bolts
    Las Cruces, NM
    I would reinstall those also. You won't be able to easily see them anyway.
  5. #5 Re: ARP Header bolts
    Barksdale AFB, LA
    Sounding less cost effective if I'm buying a set (even of six only) so I can only use three or four.
  6. #6 Re: ARP Header bolts
    Bastard Reptile's Avatar
    Kansas City, MO
    Kinda the way I was...I got them and only used the ones for the front to make it look good, and replaced those knuckle scraping studs in the back...I still had like 4 left over.
  7. #7 Re: ARP Header bolts
    Barksdale AFB, LA
    I'll think about it. I was hoping a spacer the length of a nut was available to make these parts work (put the spacer between the head and bracket, then bolt through all three parts).
  8. #8 Re: ARP Header bolts
    Barksdale AFB, LA
    Intense e-mailed me back and said more or less the same thing. Gonna have to think about these.
  9. #9 Re: ARP Header bolts
    Moore, Oklahoma
    I just reused my stock studs + nut when installing my headers, made the job easy IMO...
    Shawn W. Larsen
  10. #10 Re: ARP Header bolts
    Wichita, KS
    Quote Originally Posted by Iron Indian View Post
    X2
    though a few that came with my TOG's I used cuase they look cool.
    For the rear, I kept the knuckle bushing studs cause I am still using them, that stupid bracket that hold the engine cover on and what two plug wires in a clip and the O2 sensor wire up...I still use that bracket, thats what I have my nitrous solenoids mounted to.
    ~F~
  1. Header wrap anybody ?
    Last Post: 06-26-2008, 06:29 PM
  2. TOG Header owners, please step in...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-28-2008, 12:18 AM
  3. SLP Header Installed
    By J_Ferguson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2008, 03:02 PM
  4. TOG Header Question...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 01:00 AM
