Thread: Towing Capacity
Results 1 to 8 of 8
  1. #1 Towing Capacity
    SE Level Member 07GXPLS4's Avatar
    Oct 2011
    Kalamazoo, MI
    I have an 07 Grand Prix GXP. Everything I see says that it's rated at 1000 lbs. I'm looking at towing a Popup camper. Tongue weight is 120 lbs and a total loaded GVWR of 2000 lbs. I know it's a uni-body, but only a 1000 lbs towing? Plenty of power/trans/brakes. Has anyone towed a SMALL popup or camper. What type of hitch are you guys using?
    I'm not climbing mountains. I'm in Western MI and have a few hills, but nothing serious. My main campground is only 20 highway miles away. Farthest trip would be 300 miles max to camp with/by my parents. Thanks for any info
  2. #2 Re: Towing Capacity
    GT Level Member Lenny's Avatar
    Jul 2010
    41 R QR 51938 02935
    transmission is pretty much made of glass
    2007 Grand Prix GXP
  3. #3 Re: Towing Capacity
    its the same trans as the gtp's.
    because its 04+ is does have hardend parts and can tow a certain amount of wieght.
    If you did end up towing with it, keep it in 3 and not D, so it dont go into fourth gear.
  4. #4 Re: Towing Capacity
    you should be fine, may be super slow and break your trans but you should make it
    SMGPFC Member #10
  5. #5 Re: Towing Capacity
    Jul 2011
    Robert, La./Pensacola, Fl.
    Most tail dragers are limited to 1000k towing since the drive wheels are up front.
  6. #6 Re: Towing Capacity
    Florida
    I've pulled 1800lbs on my 2002 GTP, never had an issue, but I never got out of 3rd either, or about 40mph.
  7. #7 Re: Towing Capacity
    utah
    this is fail fail fail
  8. #8 Re: Towing Capacity
    Topeka, KS
    Want to tow stuff? Get a truck!
  1. coolant capacity of 94 3.1 GP?
    By restlessrobb in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-04-2011, 01:32 PM
  2. oil capacity
    By 3100sfi in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-06-2011, 09:51 PM
  3. towing the gp
    By stlunatics2oo3 in forum Off Topic Discussion
    Last Post: 01-10-2011, 10:33 PM
  4. Oil Capacity?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2009, 02:33 PM
  5. Towing with a GTP
    By bryguy322 in forum General Tech Discussion
    Last Post: 05-02-2009, 10:02 PM
