Thread: injector wire diagram or question
Results 1 to 17 of 17
  1. #1 injector wire diagram or question
    Jun 2011
    Middletown, NY 10940
    Car keeps popping injector fuse the second u turn the key and wont start,
    I checked harness for continuity then disconected from all injectors and fuse still pops...
    I dont know if any other components are on that circuit and I was wondering if anyone knows of has diagram for it??????
    if it is not some other component I figure I got a skinned wire somewhere but worth checking other components first??
    appreciate any advice - money is tight so didnt want to go to alldata,
    thanks
    Daily Regal GS
    Weekends Spyder GST
  2. #2 Re: injector wire diagram or question
    Work just ratcheted down on photobucket yesterday....I'm cryin here. I'm honestly crying.
    It's in my photobucket Billboost37 under helpful pictures, either regal or GP. It's the same for both.
    But there's nothing on the circuit. It's power from the fusebox direct (you can check with key on.) and then the pcm pulses the injectors. It won't pulse if it doesn't see the ICM pulse though.
  3. #3 Re: injector wire diagram or question
    Jun 2011
    Icm pulse? From computer?
    i swapped new comp in so is it safe to think it is not that and just a skinned wire somewhere?
    Daily Regal GS
    Weekends Spyder GST
  4. #4 Re: injector wire diagram or question
    Is anything safe?
  5. #5 Re: injector wire diagram or question
    Feb 2009
    flintnasty MI
    There really is no diagram, the injector wires go straight to the fuse box, and the signal wires go straight to the pcm, they do not have any inbetween connectors or junctions.
  6. #6 Re: injector wire diagram or question
    Which is why...last night I said to find the fuse labeled FI.
    Add check for power with key on at injector connector.
  7. #7 Re: injector wire diagram or question
    Jun 2011
    Can signal wire blow fuse? Or is power wire that only does that?
    Daily Regal GS
    Weekends Spyder GST
  8. #8 Re: injector wire diagram or question
    Check what we gave you to check and report back.
    I'm not into running in circles.
  9. #9 Re: injector wire diagram or question
    Jun 2011
    Its popping fuse on Key on before you even crank the engine, so I got nothing!
    what should I check next?
    Daily Regal GS
    Weekends Spyder GST
  10. #10 Re: injector wire diagram or question
    Feb 2009
    flintnasty MI
    Unplug the injectors, and see if it is still blowing a fuse.
    If so, one of the 6 pink power wires are causing you an issue.
  11. #11 Re: injector wire diagram or question
    Jun 2011
    I did unplug and still pop fuse.. I cant find thebad wire unless it is tuccked under dogbone area above radiator
    Daily Regal GS
    Weekends Spyder GST
  12. #12 Re: injector wire diagram or question
    Jun 2011
    im gonna get some more time tomorrow morning to look and untuck the entire thing from injector to fuse box - it better be there or im at a loss
    Daily Regal GS
    Weekends Spyder GST
  13. #13 Re: injector wire diagram or question
    Thought the other night you said Regal. But pretty sure this is on the GP. Either way the diagram should be about the same. This is an 00GP schematic
  14. #14 Re: injector wire diagram or question
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Just an update................... Ed did what was suggested to him about a month ago, and now his car is fixed...................
  15. #15 Re: injector wire diagram or question
    Jun 2011
    No u make it sound like it was a simple fix I ignored lol and honestly I was thinking more of swaping than fixing.. But anyway it seems to be running now
    Daily Regal GS
    Weekends Spyder GST
  16. #16 Re: injector wire diagram or question
    Right..
    IC pump and some other things are a wiring nightmare on the car. IC pump or something went bad and took out a lot more than just the one item.
    Improperly fused electrical nightmares should be fixed asap when you are aware of them. That way you find the issues, fix them and know how things are done afterwards.
    The IC pump should only have gotten a signal for a relay from the FI circuit. Nothing more. Therefore if the IC pump was bad, it should have blown it's own fuse..not the fi fuse.
  17. #17 Re: injector wire diagram or question
    Orange County, NY
    Quote Originally Posted by TeacherCreature View Post
    LOL, it was a simple fix, you keep blowing the same fuse, you check the wiring for that circuit. The wiring for the circuit includes everything from the fuse panel to the ground.
    "Is there anything spliced into that circuit? Did you check behind the fuse panel?"
  1. power wire question?
    By Dragonblaze in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2010, 01:23 PM
  2. injector swap question
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2009, 05:23 PM
  3. amp remote wire question
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:44 PM
  4. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
  5. 06 gp GT wire harness diagram
    By merciero in forum General Tech Discussion
    Last Post: 04-05-2009, 08:59 PM
