im going to be replacing my struts and springs, and was going to go with rockauto's moogs springs and noticed they only have them in for the coupe's.. can i use them on my sedan??
Springs are the same in the Coupe and Sedan...yes.
They're the same springs coupe or sedan for any gp 97-08.
I was wondering about this as well. I know they're supposed to be the same, but Moog has 2 different numbers listed for the GP rears, and the only difference I can see in the descriptions is coupe vs. sedan.
MOOG Part # 60197 More Info Sold In Pairs
Rr Susp; Coupe; Supercharged; Constant Rate Springs
MOOG Part # 60199 More Info Sold In Pairs
Rr Susp; Sedan; Supercharged; Constant Rate Springs
MOOG Part # CC670 More Info Sold In Pairs
Frt Susp; Supercharged; Variable Rate Springs
Also, are the Regal springs the same ride height and everything as the GPs? Because if they are, I will probably go with Regal springs for the rears since they're variable rate. Moog shows only one # for the Regal rears (same # as the GPs for the fronts).
MOOG Part # CC689 More Information About this Part Sold In Pairs
Rr Susp; Variable Rate Springs
compare AC Delco numbers.
