Thread: Gas tank and filler neck
Results 1 to 9 of 9
  1. #1 Gas tank and filler neck
    Sep 2011
    Canada
    Hey all. I put some gas in the tank today and a few hours later I went back to the car and smelled gas. I saw dripping. Got the car to the autoclub and put it up on the hoist. It's dripping from somewhere near the top left side. So, I picked up a filler neck and gas tank. I'm replacing them both Sunday to be safe. I'm wondering if anyone has any tips or tricks that might have done this before. I've never changed a gas tank on a Grand Prix before, but have on other cars.
  2. #2 Re: Gas tank and filler neck
    its all the same, take the lines off take the straps off and take it out,,, mayb not in that order but you get what i gettin at
    SMGPFC Member #10
  3. #3 Re: Gas tank and filler neck
    Sep 2011
    Canada
    Yup I gotcha. Just wanted to be sure it was straight forward.
  4. #4 Re: Gas tank and filler neck
    yea just do the normal stuff and itll be fine
    SMGPFC Member #10
  5. #5 Re: Gas tank and filler neck
    Sep 2011
    Canada
    Nice. The body of the car is in awesome shape. The engine has a leaky front manifold which is an easy fix. I just had to put rear struts on it and run new rear brake lines. Sucks the gas tank was bad but I figure it should be a pretty good car once it's done.
  6. #6 Re: Gas tank and filler neck
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    if its a 97 the filler neck is different from the 98 up. i had to take the evaperator canistor (if thats what it is) off on my 97. had to take the plastic thing off that the fuel door rivits to. pretty easy job.
  7. #7 Re: Gas tank and filler neck
    Sep 2011
    Canada
    Good to hear and thanks for the tip. Mine's a 2000 but I'll watch for that evap cannister!
  8. #8 Re: Gas tank and filler neck
    Sep 2011
    Canada
    Well I finally got the tank and filler neck in. I had to cut the straps because there was no way I was getting the strap bolts out! So, took a little longer to weld them back. I also had to make my own vent line since the metal had rusted in the plastic fitting and wasn't coming out.
  9. #9 Re: Gas tank and filler neck
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    I think I would replace the straps with new ones, rather than trust welded straps. I'm partial to homogeneous steel, though, when it's possible.
  1. gas filler neck
    By gpgt98 in forum General Tech Discussion
    Last Post: 07-23-2011, 01:19 AM
  2. Oil filler neck removal?
    By TheMayor937 in forum 5.3L V8 (LS4)
    Last Post: 02-26-2011, 08:13 PM
  3. water in oil filler neck
    By m1sterb0b in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2011, 02:07 PM
