Thread: most common p0300 code fix
Results 1 to 5 of 5
  1. #1 most common p0300 code fix
    Michigan
    check engine light came on today code is p0300 autozone says plugs and wires what do you guys think?
  2. #2 Re: most common p0300 code fix
    Sep 2011
    Canada
    Possible causes for a random cylinder misfire are: Bad spark plug, bad spark plug wire, bad coil pack, plugged cat. How long have the spark plugs been on the car? Spark plug age is about 80000km or 50000mi.
  3. #3 Re: most common p0300 code fix
    Depends on a lot. Platinum plugs get chewed up quick in our waste spark ignition systems. I've seen them go bad in as little as a week and as much as a couple of months.
    P0300 is most commonly caused by plugs and wires.
  4. #4 Re: most common p0300 code fix
    Michigan
    the check engine light shut off on it's own for so
    e reason
  5. #5 Re: most common p0300 code fix
    That's common too. Means crap didn't happen during this start cycle. Don't believe that it's fixed. You still need to fix it.
  1. Stumped with P0300 code
    By zach101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2011, 04:56 PM
  2. Code p0300 misfire caused by cat?
    By randywalsh in forum General Tech Discussion
    Last Post: 09-05-2011, 09:44 PM
  3. Random Misfiring P0300 Code
    By spcguy88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2010, 09:44 PM
  4. Sputtering and P0300 code
    By grngt97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 02:12 PM
  5. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
