Thread: zzp pcm pros and cons
Results 1 to 20 of 45
  1. #1 Re: zzp pcm pros and cons
    May 2008
    staten island,NY
    When i first bought my GT i purchased a DHP. When i went M90 i bought ZZPs tune for the blower. The first PCM would stall the car out, and only command 6 degrees of timing, and dump fuel like crazy. They sent me another one and it fried when i was having the car dyno tuned. I bought an intense PCM and its still in the car now, re tuned a few times with the blower and now how it sits with the turbo. Personally id choose a DHP or Intense, then again i have my own tuner. Is there a GM shop local to you? if they can tune LS cars the 3800 shouldn't be an issue.
  2. #2 Re: zzp pcm pros and cons
    Jan 1970
    Maquoketa, Iowa
    Going with what six said above, one of the main things needed to be looked at is what the tune was designed for and what you're actually running for mods. There actually was a list created about 5-7 years ago that listed motor failures, mods and pcm being used, have to dig up the link.
    If you actually open up each of the tunes in an editor you will see some major differences in the zzp's from intense/dhp.
  1. Cons to HID's?
    By Frank217 in forum Visual/Body Modifications
    Last Post: 06-15-2010, 10:00 PM
  2. Pros and cons of GTP??
    By up in boost in forum Off Topic Discussion
    Last Post: 01-14-2010, 02:23 PM
  3. pros and cons
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 11:19 PM
  4. pros and cons of screen removal?
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 05:52 PM
  5. A Little Help from you Pros.
    By Scott B in forum General Tech Discussion
    Last Post: 05-13-2008, 08:31 PM
