Thread: Cricket chirping and other odd noises
Results 1 to 20 of 32
  1. #1 Cricket chirping and other odd noises
    Indiana
    I am hearing a cricket chirp noise in the car and its rather annoying. I notice it at all times. It sounds like its coming from somewhere behind the dash on the driver side (not heard under the hood). The one thread I saw on here was about the idler/tensioner pulley but noise is coming from the wrong side.
    The other noises are random creeks and clicks, maybe water behind the dash? (hard to describe) coming from where I think is passenger side dash area.
    We checked all fuses, everything is ok. No SES lights, runs fine, electrical components as far as lights are solid and do not flicker.
    Any ideas?
  2. #2 Re: Cricket chirping and other odd noises
    Omaha, NE
    Are you sure there isn't an actual cricket?
  3. #3 Re: Cricket chirping and other odd noises
    Indiana
    That's what boyfriend told me until he heard it the other night for himself. It never stops until the car is turned off and its very consistent. I've also been hearing it for awhile before the crickets came out.
  4. #4 Re: Cricket chirping and other odd noises
    blend door actuators freaking out? mines moving all the time sounds like someones under the dash moaning....and i get no heat, just ice cold a/c lol
  5. #5 Re: Cricket chirping and other odd noises
    Omaha, NE
    I would say its pulley related. Try spraying them with pb blaster or wd40. If your belts are old they may be loose/ slipping a bit.
  6. #6 Re: Cricket chirping and other odd noises
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    Go buy a few house geckos at Petco and let them loose in your car. If the cricket noise stops, you know it was a real cricket, cuz they ate it. :P
    2004 GT2 Leather, Sunroof, heated seats, other stuff, but only a little DIC. Also, Kawi Vulcan 2000 http://tinyurl.com/ophidia
  7. #7 Re: Cricket chirping and other odd noises
    Texas
    To eliminate the pulleys and tensioner just remove the belt and start the car. Give it a little gas and see if it goes away. If it does then you have a tensioner or pulley problem. Reinstall your belt and dip some water on the belt. If it stops chirping you have a tensioner problem. I just replaced mine 2 days ago.
    And when you have the belt off turn the alt. pulley it's possible the bearing is going out. Listen for the chirp as you turn that pulley.
    85 Corvette
    01 TA
    03 Z06
  8. #8 Re: Cricket chirping and other odd noises
    MO
    maybe you have a cricket in your car? I do.
    <brandonl2000> LMAO D!!
  9. #9 Re: Cricket chirping and other odd noises
    Turn your hvac totally off, does the sound go away?
  10. #10 Re: Cricket chirping and other odd noises
    Indiana
    I'm going to try spraying the pulleys with wd40 first tonight. To maybe elimante something.
    Who knows, it may be a real cricket but it never stops even when you smack the dash.
    And bill- it still does make the noise with it off, but the hvac does seem to run kinda hard and other noises are noticed. there is one of those "a leak detector has been placed in the hvac system" stickers. But its worked fine and ice cold all summer. It did have the motor replaced with one out of a Buick before I bought it if that matters any.
  11. #11 Re: Cricket chirping and other odd noises
    Drip water on the belts first before WD40. WD can be messy and ensure you wear safety goggles.
  12. #12 Re: Cricket chirping and other odd noises
    Indiana
    Ok. Do this asthe motor is running? Sorry if that's a stupid question. And to elimante that its not a live cricket, could I spray some bug killer around the car and by the firewall?
  13. #13 Re: Cricket chirping and other odd noises
    If you like the smell of bug killer.. spray away.
    Yes on the water while running.
  14. #14 Re: Cricket chirping and other odd noises
    Indiana
    Ok, I'll try the water and inspect belts and pulleys tonight.
    I tried recording the sound, but phone couldn't pick it up.
    I'll report my findings in a day or so.
  15. #15 Re: Cricket chirping and other odd noises
    Pennsylvania
    Um, stock intake box? They sound like crickets if you listen close.
  16. #16 Re: Cricket chirping and other odd noises
    I live here. TLSheff's Avatar
    LOL I had a similar sound in mine. Doubtful yours is as simple as mine was but over time and driving the panel under the steering wheel, the one your knee would hit if you lifted it up to the dash, was vibrating... A firm hold and it would stop, I took it off and adjusted the clips and added some foam padding and no more sound.
    Like I said, its prolly not that simple, but something to consider. If you can't hear it under the hood with the hood lifted, Its most likely in the cab with you... cricket or not
  17. #17 Re: Cricket chirping and other odd noises
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    I have the cricket sound, too, and learned what it was about 4 months ago. It goes away when I turn off the radio. I don't mean turning the volume all the way down, but turn it off, completely.
    See if that kills it.
  18. #18 Re: Cricket chirping and other odd noises
    Indiana
    Ok, The sound went away when before i tried the water test. So I went ahead and did it anyways and it didnt come back until today on my way between jobs. THis time it wasn't very consistent. I turned the radio OFF (took face plate off) and no HVAC was on. I did not try wd-40 yet.
    Could the fuel pump make that kind of noise?
    Its not loud like a cricket but its the steady chirp like sound they make.
    Any other tactics to try? I'll try the wd-40 tonight after work.
  19. #19 Re: Cricket chirping and other odd noises
    where you from in indiana? I'm over there every other weekend, sometime more than that to visit mom and dad in geneva.
  20. #20 Re: Cricket chirping and other odd noises
    Indiana
    Not to far from Geneva. Wells county
  1. chirping noise
    By gpgt98 in forum General Tech Discussion
    Last Post: 07-07-2011, 07:13 AM
  2. squeak/chirping noises
    By blight86 in forum Introductions/Noob Questions
    Last Post: 03-15-2011, 03:15 PM
  3. chirping
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-24-2010, 07:07 PM
  4. Chirping Noise
    By TeeWX in forum General Tech Discussion
    Last Post: 09-02-2009, 07:29 PM
  5. Replaced engine. Now cricket appears. gotta kill it
    By FlatlinerD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2008, 10:42 AM
