Thread: Cricket chirping and other odd noises
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Cricket chirping and other odd noises
    i could take a look at it sometime if you want. I have to swap dad's clutch in his truck soon probably in a few weeks if you still have the problem then.
  2. #22 Re: Cricket chirping and other odd noises
    Texas
    If the sound went away when you did the water test then it's the tensioner. They are around $75 from the parts store because it's an entire assembly. Takes about 15-20 minutes to do with standard hand tools.
    85 Corvette
    01 TA
    03 Z06
  3. #23 Re: Cricket chirping and other odd noises
    Indiana
    It stopped before the water test. It did not do it that day at all. So I went ahead and did water anyways that night. If its doing it when I get off work tonight ill try it again.
  4. #24 Re: Cricket chirping and other odd noises
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    When I have the temperature setting all the way up, or all the way down, I hear the cricket sound. When I have it somewhere toward the middle range, I don't hear it. The sound goes with the actuator motor moving is what I'm saying. I haven't looked to see if it's constantly moving back and forth or not, but just thought I'd post it.
  5. #25 Re: Cricket chirping and other odd noises
    Indiana
    Mine still makes if hvac is off or on. I even took radio off and still heard. I'm at a loss for what it is since its not coming from the pulley side of motor.
  6. #26 Re: Cricket chirping and other odd noises
    Pennsylvania
    I'm still convinced that chirping is actually a whistle from the stock airbox/filter.
  7. #27 Re: Cricket chirping and other odd noises
    Can you record this sound possibly and video of it? And show us where it sounds like its coming from?
  8. #28 Re: Cricket chirping and other odd noises
    Indiana
    Quote Originally Posted by SlowNA06 View Post
    I'm going to eliminate the stock stuff and do a open cone
    Quote Originally Posted by slick2500 View Post
    I tried back when I first made the thread and it wouldn't pick it up.
    I washed the engine down last night and it hasn't made any noise since then.
    When sitting in the driver seat it sounds like its coming from behind the radio/dash area?
  9. #29 Re: Cricket chirping and other odd noises
    Indiana
    Well, it started making the noise again today.
    Silly question, could it be connected to the AC clutch? (cuz it is going bad)
    But it makes the noise with HVAC off and on, so I guess it wouldn't be that.
    I didn't have a chance to cut out the intake box this weekend.
    I need to clean up the filter and find time to tackle the job.
    smh.
  10. #30 Re: Cricket chirping and other odd noises
    Good thing you posted in here because it reminded me, I was driving the grocery getter and turned off the radio and I could hear this noise that sounded like crickets and if I held onto the dash board the sound stopped if I let go it started again. There is a possibility that your noise could be the same as the noise that car makes. I believe its the dash rubbing against something that makes that noise. See if holding the dash makes the sound go away.
  11. #31 Re: Cricket chirping and other odd noises
    Indiana
    I've been wondering that too. Because I don't remember when it started making the noise, but I do remember hearing it after the aftermarket radio was installed...so possibly the removing of dash parts made something unhappy and it makes noise now?
    What area of the dash did you push on?
    If its making it tomorrow, I will give it a try.
    I know smacking the dash super hard doesn't help, just hurts my hand
  12. #32 Re: Cricket chirping and other odd noises
    I would pop the dash bezel off make sure the radio bracket is good and tight. See if any of the bezel clips are missing or bent or anything like that.
    And when I say grocery getter I mean the Caprice. But I just pushed down on the top of the dash and it went away.
  1. chirping noise
    By gpgt98 in forum General Tech Discussion
    Last Post: 07-07-2011, 07:13 AM
  2. squeak/chirping noises
    By blight86 in forum Introductions/Noob Questions
    Last Post: 03-15-2011, 03:15 PM
  3. chirping
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-24-2010, 07:07 PM
  4. Chirping Noise
    By TeeWX in forum General Tech Discussion
    Last Post: 09-02-2009, 07:29 PM
  5. Replaced engine. Now cricket appears. gotta kill it
    By FlatlinerD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2008, 10:42 AM
