As, this is my first post and im a noob everyone go easy on me, I signed up and im in need of some assistance. I have been having problems with my blower motor, when I would hit a bump, it would stop, when I hit another it would pop back on, after taking a look under the passenger side dash, I seen what was going on, the 5 wire control module that plugs into the resistor had shorted out and if you wiggled the wire it would work, and then cut out, so after going to the local GM dealer, I ordered the control module, when i recieved it I cut and crimped wire by wire matching them up as they were cut, low and behold nothing works, its as if the power isnt getting there, before anyone says anything about the blower motor i took it out and hooked it up to a battery and it was spinning around like crazy. I traced the wires that I cut, back to the heaterbox on the console, and there appears to be power there. I am completly lost all i did was match wire for wire and crimped them. does anyone have any ideas, ive checked the fuse, the heater box, and the motor itself and they are all fine, any ideas would be awesome, I apoligize for the novel
