Thread: stupid oil pressure switch
Results 1 to 16 of 16
  1. #1 stupid oil pressure switch
    michigan
    That's what its called I guess. Its next to the oil filter. Anyways it seemed to have been bad cuz it was draining oil out of it, the front not the threaded part. Is this common for those? Anyways, $14 part and easy fix, now just gotta keep an eye on it for awhile and make sure it doesn't leak again or if I have any other leaks besides that one.
  2. #2 Re: stupid oil pressure switch
    Charles City, IA
    Pretty common.
    SMGPFC Two Nipple General
  3. #3 Re: stupid oil pressure switch
    michigan
    Ok, the guy at autozone looked baffled by it.......which is pretty common as well!! Lol
  4. #4 Re: stupid oil pressure switch
    i blew 3 of them in the last year, it now has a plug in the hole till i get a oil pressure gauge installed. the first one i replace went bad in a week. defiantly keep an eye on it for a while.
  5. #5 Re: stupid oil pressure switch
    michigan
    Ugh.....really? This stupid issue is fuggin up my driveway terribly! Asphalt tends to not let stains go too easily.
  6. #6 Re: stupid oil pressure switch
    all 3 times it cost me a oil change, they blew out on the highway, and i didnt know it till i saw smoke out the back, and de greasing the whole under side of my car too.
    they seem to like to drip/pour on the axle and sling oil all over the place.
    they really should make a better sensor.
    the first time it leaked all over the ground and i only had the car for a week, so i really freaked out. i had no idea what was leaking till i got it in the air and really got a good look at it.
    the way i was checking mine was turn the wheels to the left and look behind the back of the pass side wheel at the sensor while its running. a mag light (big flash light) helps to see better as well.
  7. #7 Re: stupid oil pressure switch
    michigan
    Yeah, pretty easy to diagnose. And makes a huge mess on the undercarriage. Went thru 3 big cans of brake clean and still a mess. Waiting for a big rain so it might flush it out a bit. Lol
  8. #8 Re: stupid oil pressure switch
    i used a whole can of gunk foamy engine cleaner, that chits the chit!
    redid the whole engine and under side of the car. 3 times.
    rain wont help, lol but it will keep your undercarriage from rusting if the oil is left there lol
    i was really glad i did clean it up when i was doing my rack and pinion though. i was working on it with my feet under the back seat it seemed, and my head under the rack, no fun at all. im a lank at 6'6.
  9. #9 Re: stupid oil pressure switch
    Tyipcally they will only seep/slowly leak. Which gives you a chance to swap them out.
    Scotty...what brand should we be staying away from?
  10. #10 Re: stupid oil pressure switch
    i used what ever pep boys sells and what autozone sells, the brass plug is leak free and cost a dollar and 50 cent.
  11. #11 Re: stupid oil pressure switch
    michigan
    Doesn't that throw a cel or anything?
  12. #12 Re: stupid oil pressure switch
    no cel, the low oil light comes on when you have under 5 psi of oil pressure, by then its to late and your engine is dead already.
  13. #13 Re: stupid oil pressure switch
    If you unplug the sensor, it doesn't read low pressure and therefore no light. It's a bit backwards from what you'd expect.
  14. #14 Re: stupid oil pressure switch
    michigan
    If it fails on me one more time ill just plug it then.
  15. #15 Re: stupid oil pressure switch
    Pennsylvania
    Quote Originally Posted by twol8uluz View Post
    Install pressure gauge.
    Impress girls.
    Profit.
  16. #16 Re: stupid oil pressure switch
    michigan
    Lol, I plan on getting gauges down the road too, guess I know what one of them will be!
  1. im so stupid...
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 02-12-2011, 05:24 PM
  2. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  4. Where is A/C pressure switch?
    By PCweber in forum General Tech Discussion
    Last Post: 03-29-2009, 07:13 PM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
