Thread: LOTs of helpful modding/3800 info
Results 1 to 20 of 30
  1. #1 LOTs of helpful modding/3800 info
    Grand Island, Nebraska
    Found this theselinks today. Some very useful stuff. Anything from valvetrain geometry to intake flow rates to explanations of KR. all credit goes to ZZP unless otherwise noted in the article, and not me.
    I believe these to be mostly accurate and are parallel to what I have been hearing members tell other members.
    *Disclaimer* *dont believe everything you read on ZZP*
    Series 3 HV3 intall
    Penetrating Oils Compared
    Belt sizes, routing and pulley diagram
    Valve springs and retainers
    Pushrod length and lifter preload
    Intercooler pumps
    R&D on the Walbro fuel pump by Dig Ken
    FREE MOD: Ground Wire Upgrade
    FREE MOD: Removing the Engine Brackets
    FREE MOD: Larger oil filter
    FREE MOD: Improving Throttle Body Airflow!
    Mods You Don't Need
    Intake Designs, Airflow Testing and Theories
    How to Achieve Neck Snapping 60' Launches
    About Knock Retard (KR)
    KR - How To Fight?
    U-Bend Replacement Test by Jim Wierzbicki
    97 - 06 GTP Model Differences
    Eliminating KR
    Drag Racing Tips
  2. #2 Re: LOTs of helpful modding/3800 info
    Omaha, NE
    Yep... Old articles there...
  3. #3 Re: LOTs of helpful modding/3800 info
    i stopped at ZZP
  4. #4 Re: LOTs of helpful modding/3800 info
    Omaha, NE
    i stopped at ZZP
    Good choice.
  5. #5 Re: LOTs of helpful modding/3800 info
    Um yeah I don't believe anything they say, like its safe to run a 3.5 on a stock car without mods........ their catback makes more hp than anyone else's
  6. #6 Re: LOTs of helpful modding/3800 info
    If you'd read they said the stock flows to 300whp. I know they are old articles but that doesnt mean they are all bogus. This is for the guys who havent been here forever and would still learn from reading the safely modding your 3800 thread.
  7. #7 Re: LOTs of helpful modding/3800 info
    Unforutunately there's possibly more bad info in there than good.
    "run a 3.4 pulley and our pcm, your car will love it".
  8. #8 Re: LOTs of helpful modding/3800 info
    "If you plan on doing other modifications as well then the 3.4" pulley is a better choice. It requires a smaller belt or an oversized tensioner pulley. The 3.4 will give ~25 additional HP. Supporting mods that are required include colder Tstat, stage 1 throttle body, colder spark plugs, cold air intake, TB spacer, we recommend at minimum installing the Ubend delete, but the best exhaust mod is our downpipe."
    Yes the TB spacer is bogus, (unless its needed for their tb?)
    Im not asking for this to be a sticky, but zzp usually tests the things they claim. If it would be more helpful I could separate out the ones that arent exactly relevant anymore.
  9. #9 Re: LOTs of helpful modding/3800 info
    Dude...are you kidding?
    This is the exact reason I typed this:
    http://www.grandprixforums.net/safel...car-17482.html
    Most of...if not all of that info is old, outdated, and wrong.
  10. #10 Re: LOTs of helpful modding/3800 info
    ZZ Performance
    Jason Bagnell recently purchased a Competition VS Cam and placed in his 2000 Pontiac GTP.
    From Jason's email on 02/26/2004:
    "Hey Zooomer... I just got my car back from the shop and the VS cam is running beautifully!!!
    RWHP (Horsepower) Before / RWHP After: 231.2 / 265.5
    RWTQ (Torque) Before / After: 258.7 / 276.4
    Net Gains from VS cam & 90 lb spring upgrade: 34.3 HP / 17/7 Torque
    Equivalent Engine HP rating from Dyno computer after adjusting for drivetrain loss: 326HP!!!
    KR=0 .... 0.1 at the most infrequently!!!
    Awesome...
    KR was 5-6 at times before the cam install!"
    - Jason of JBC Services, Feb 26, 2004
    I'd be curious to see what he'd dyno if he had a proper pulley on the first time.
  11. #11 Re: LOTs of helpful modding/3800 info
    RWHP...
    I had no idea.
  12. #12 Re: LOTs of helpful modding/3800 info
    Better?
  13. #13 Re: LOTs of helpful modding/3800 info
    HV3 install is from one of our members here.
  14. #14 Re: LOTs of helpful modding/3800 info
    Yes i know. They gave him credit.
  15. #15 Re: LOTs of helpful modding/3800 info
    ZZ Performance
    the new info just coming into light about the PCM learning timing I have since switched to using the 3.4 and the 3.25 for daily driving.
  16. #16 Re: LOTs of helpful modding/3800 info
    http://www.zzperformance.com/downloa...omparison1.pdf
    15* difference for the cost of ceramic coating?
    Which is $300-600 depending on what you're having done.
    3% power loss from higher IAT.
    (high estimate based CAI_Primer_Thermal as well as assuming that the external temp of the intake tubing is the same as the internal... which it probably isnt.)
    280 CHP.
    3% is 8.4 HP.
    *.80 for 6.72 whp.
    Was looking at ported blowers on 540 WHP CTS-V... He gained 20 WHP.
    3.7% increase.
    so 3.7 on 280 is 10.36 CHP.
    8.3 WHP for the cost of a ported blower. (free to 500 for ZZP)
    Interesting when you put into perspective the cost of these mods for the gains you achieve.
  17. #17 Re: LOTs of helpful modding/3800 info
    I think you care too much.
    Get headers.
    Gain 20 FWHP.
    Cheaper than a ported blower and a bunch of other crap.
    I go fastest.
  18. #18 Re: LOTs of helpful modding/3800 info
    280 CHP.
    3% is 8.4 HP.
    *.80 for 6.72 whp.
    3.7% increase.
    Are you saying thats good or bad? I would take 8WHP anyday, but maybe not for $500+. Some people like to do whatever they can to go faster.
  19. #19 Re: LOTs of helpful modding/3800 info
    He's saying for $ per HP...ZZP's prices and the gains had on these cars is whack.
  20. #20 Re: LOTs of helpful modding/3800 info
    Quote Originally Posted by JoRoW99 View Post
    Thats on a VERY expensive port job...
    Looking at other options like intercooling.
    NOT WORTH MONEY.
    1500 by the time you're done.
    for 40 whp?
    Cam? Depends on what size.
    If you're doing 34 WHP gains for the cost of the cam, gaskets, springs, retainers....
    You're looking at:
    330 cam
    100 springs/retainers
    200 gaskets/fluids.
    630+ for 34 whp versus that 8 WHP you were so excited about for that 550 dollar blower port from ZZP.
    Much better returns.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 3 Weeks Ago, 11:56 PM
  2. YO dudes/gals - Newbe here to read lots of good info.
    By blu fuz in forum Introductions/Noob Questions
    Last Post: 05-24-2012, 09:52 PM
  3. Replies: 60
    Last Post: 12-07-2009, 11:05 AM
  4. Safely Modding Your 3800 Powered Car!!
    By blueguy in forum General Tech Discussion
    Last Post: 07-05-2009, 10:43 PM
