Thread: transmission mount question?
Results 1 to 7 of 7
  1. #1 transmission mount question?
    Jul 2011
    bristol,va
    i bought a transmission mount from autozone and noticed once i installed it the motor sits down lower on the transmission side. do i have the wrong mount? they only said there only showing one part number, thanks
  2. #2 Re: transmission mount question?
    PA
    Quote Originally Posted by hardrocrick View Post
    Sometimes the replacement mounts are shorter than the stock ones. You can try a couple different brands from different stores and measure them all, then compare it to your stock one.
    2001 GSE
  3. #3 Re: transmission mount question?
    Jul 2011
    bristol,va
    my stock one is destroyed
  4. #4 Re: transmission mount question?
    PA
    Then get a stock one from GM and measure it.
    2001 GSE
  5. #5 Re: transmission mount question?
    Jul 2011
    bristol,va
    cool thanks
  6. #6 Re: transmission mount question?
    Charles City, IA
    Whats the mount look like? Some of the after market "solid ones" are junk and sink down.
    SMGPFC Two Nipple General
  7. #7 Re: transmission mount question?
    Jul 2011
    bristol,va
    it is from autozone and is supposed to be liquid filled motor mount, now the motor sits lower on the pass side, thanks
  1. Engine mount question
    By goldgp in forum General Tech Discussion
    Last Post: 09-24-2010, 08:47 PM
  2. Motor mount question
    Last Post: 08-16-2010, 07:42 AM
  3. Transmission Mount Fitting
    By PGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2009, 03:46 PM
  4. Mount question
    By kjohnson in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2009, 02:15 AM
