Thread: 1999 GTP DIC Information Center
Results 1 to 20 of 28
  1. #1 1999 GTP DIC Information Center
    SE Level Member fieldski's Avatar
    Aug 2011
    Hello fello GTP enthusiasts.
    I have a 1999 GTP. I recently had my battery die and I replaced it with a Optima yellow top. After replacing my battery, the DIC ( Information Center, Boost, Doors...ect ) has no display. I don't even see a faint display, it is just black. I would assume that it is dead and or something else is at play here.
    How do I even start to diagnose this? I have been doing all of my own mods/work on my GTP since the beginning, but this is beyond me.
    Any input/thoughts would be great.
    Fieldski
    1999 Grand Prix GTP
    [Thrasher Modular Pulley System / 3.4"][K & N Intake / Home Made][SLP PowerFlo Cat-Back][180° Thermostat][Transmission Cooler][Gatorback Belts]
  2. #2 Re: 1999 GTP DIC Information Center
    Charles City, IA
    I would start checking fuses. Only thing I can think of is you arc'd a cable while changing batteries.
    SMGPFC Two Nipple General
  3. #3 Re: 1999 GTP DIC Information Center
    Aug 2011
    I thought about that. all the fuses in the fuse box seem ok. What about fusable links?
    1999 Grand Prix GTP
  4. #4 Re: 1999 GTP DIC Information Center
    Charles City, IA
    Only fuse-able links are going to the starter.
  5. #5 Re: 1999 GTP DIC Information Center
    Aug 2011
    OK, so where do I start? All the fuses in the fuse-box are good. Do I just replace the unit? Or do I bite the bullet and take it to a GM dealership. This is not super necessary but I would like to see the boost gauge work again.
    fieldski
    1999 Grand Prix GTP
  6. #6 Re: 1999 GTP DIC Information Center
    Aug 2011
    There is so much knowledge here. I hope someone has an idea. I could replace the unit or ??? Come on peeps.
    -Fieldski
    1999 Grand Prix GTP
  7. #7 Re: 1999 GTP DIC Information Center
    Charles City, IA
    gpona.com has a service manual with wiring diagrams you can use after you register. I would start by checking for power to the info center.
  8. #8 Re: 1999 GTP DIC Information Center
    Aug 2011
    Will do, thanks for the info.
    1999 Grand Prix GTP
  9. #9 Re: 1999 GTP DIC Information Center
    Yoga city
    And if all else fails it's not like there rare, I'm sure you could find a replacement dic....haha replacement dic
  10. #10 Re: 1999 GTP DIC Information Center
    PA
    A common issue a bad ignition switch is that the DIC doesn't work. If you have other power issues like radio or HVAC not working sometimes, you may want to consider replacing the ignition switch.
    2001 GSE
  11. #11 Re: 1999 GTP DIC Information Center
    Aug 2011
    Interesting on the HVAC. My A/C is out ( figured it needed a charge ), and it doesn't seem to switch modes anymore I.E. floor to defroster. It seems to be stuck on defroster.
    1999 Grand Prix GTP
  12. #12 Re: 1999 GTP DIC Information Center
    PA
    Quote Originally Posted by fieldski View Post
    That is a different issue. The selector for the air deflectors is vacuum controlled.
    2001 GSE
  13. #13 Re: 1999 GTP DIC Information Center
    Aug 2011
    Ok, so now I am back to not knowing what is going on. The HVAC system works fine, and I've never had any problems with the radio. I suppose I could just find a replacement online and take my chances. Has anyone replaced the DIC before? Just take the dash apart and remove the unit? I would assume there is just a couple of plugs/connections on the back of it?
    - Fieldski
    1999 Grand Prix GTP
  14. #14 Re: 1999 GTP DIC Information Center
    Houston
    Yep...just remove the dash bezel and there is a clip on each side of the DIC. Just push those in and remove the harness on the back of it.
  15. #15 Re: 1999 GTP DIC Information Center
    Dec 2008
    Lawndale, CA
    You could try doing a bench test.
    http://www.grandprixforums.net/bench...dic-31393.html
  16. #16 Re: 1999 GTP DIC Information Center
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    Mine had this issue, and the vac line was cracked and caused it not to change so i just cut out the bad section of line and went to autozone and bought a foot of extra vac line a little bit bigger than the one in the car and slipped the two ends into it and, bam! fixed. But that was what was wrong with mine, it may be something else with yours.
    -ljmonnin12
  17. #17 Re: 1999 GTP DIC Information Center
    Aug 2011
    Quote Originally Posted by The Guz View Post
    Thanks, that is exactly what I was looking for. Sounds like a plan for the weekend. At least I can see if the unit actually works.
    -Fieldski
    1999 Grand Prix GTP
  18. #18 Re: 1999 GTP DIC Information Center
    Aug 2011
    Quote Originally Posted by ljmonnin12 View Post
    It has been forever since I had the dash apart. How hard is it to get to the vacuum lines once I remove the front dash cover piece? How much deeper will I have to go?
    1999 Grand Prix GTP
  19. #19 Re: 1999 GTP DIC Information Center
    Houston
    You wont need to remove any vac lines to remove the dash bezel.
  20. #20 Re: 1999 GTP DIC Information Center
    Aug 2011
    I know. I'm just wondering how much work it is to fix the vac lines once I have the dash apart. I'll most likely fix/look at the vac lines when I have it all apart.
    -Fieldski
    1999 Grand Prix GTP
  1. Dim Driver Information Center
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 02-13-2012, 09:25 PM
  2. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  3. Driver Information Center
    By techn9cian99GTP in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 10:02 AM
  4. Information center ISSUE!!! HELP!!!
    By shutchin in forum General Tech Discussion
    Last Post: 07-29-2010, 05:26 PM
  5. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
