Thread: Check Gas Cap Message
Results 1 to 6 of 6
  1. #1 Check Gas Cap Message
    Jul 2011
    Atlantic Canada
    Hello everyone. I'm new to the forum and have just recently purchased an '07 Grand Prix. Recently I started to get the "Check Gas Cap" message so I purchased a new gas cap, but I'm still gettng the same message. I also pulled the codes and found P0455 (Evaporative Emission Control System Leak Detected (no purge flow or large leak).
    What else could toss out the "Check Gas Cap" message? I've tried searching the forums, but gas and cap are not allowed since they are both less than 3 characters in length. Could it be tht vapor canister purge valve or solenoid?
    Thanks in advance.
  2. #2 Re: Check Gas Cap Message
    Charles City, IA
    Its a leak somehwere in the system. Take it to a shop and have them smoke it
    SMGPFC Two Nipple General
  3. #3 Re: Check Gas Cap Message
    Jul 2011
    Atlantic Canada
    @TheOtherNick - thanks for the reply. I'd really like to tackle this on my own. Besides, I live in rural Nova Scotia so the nearest dealer is quite a distance away.
    Aside from Gas cap causing the issue, what would be the 2nd most common item to check? I've done some research and hear things like evap purge solenoid or valve but I'm not exactly sure what it looks like or where it is located. Any assistance would be great.
  4. #4 Re: Check Gas Cap Message
    SE Level Member RideMr2's Avatar
    Memphis
    2007 Pontiac Grand Prix FUEL SYSTEM, GASOLINE:STORAGE Recall
    Recall Date:
    2006-10-31
    Summary:
    ON CERTAIN VEHICLES, THE FUEL TANK IS MISSING THE ADHESIVE LAYER THAT BONDS THE BARRIER LAYER TO THE OUTER SHELL OF THE FUEL TANK.
    Consequences:
    WITH THIS CONDITION, FUEL AND/OR FUEL VAPORS COULD SEEP OUT BETWEEN THE LAYERS, INCREASING THE RISK OF A FIRE.
    Remedy:
    DEALERS WILL INSPECT THE SERIAL NUMBER ON THE FUEL TANK AND REPLACE THE FUEL TANK IF NECESSARY. THE RECALL BEGAN ON NOVEMBER 13, 2006. OWNERS MAY CONTACT BUICK AT 1-866-608-8080, CHEVROLET AT 1-800-630-2438, OR PONTIAC AT 1-800-620-7668.
    Component Affected:
    Potential Cars Affected:
    1,602
    Notes:
    GENERAL MOTORS CORP.
  5. #5 Re: Check Gas Cap Message
    Jul 2011
    Atlantic Canada
    Can someone confirm if this is the correct Evaporator Emission Canister Control Valve for my 2007 Grand Prix? I'm having a difficult time finding a site with part numbers so I'm not 100% sure if this will fit. It has 2 numbers, 214-2147 and 25932569 and I'm not sure what the purpose of the 2 numbers is.
    Thanks in advance.
  6. #6 Re: Check Gas Cap Message
    Jul 2011
    Atlantic Canada
    UPDATE: The correct AC Delco part number is 214-2106 and the GM Part number is 25932568. I replaced mine on the weekend and all is good. No more Check Gas Cap message, and the P0455 code hasn't come back after I cleared it. So far so good.
  1. DIC message "check gas cap"
    By Piggy in forum General Tech Discussion
    Last Post: 08-04-2010, 06:44 PM
  2. DIC screen message
    By Megan in forum General Tech Discussion
    Last Post: 12-18-2009, 07:28 PM
  3. Check Gas Cap Error Message
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 01:40 PM
  4. Welcome New Members - A Message For You
    By SyntheticShield in forum Introductions/Noob Questions
    Last Post: 01-27-2008, 02:32 AM
