Thread: No power to fuel pump relay from PCM? *Update issue resolved*
Results 1 to 20 of 31
  1. #1 No power to fuel pump relay from PCM? *Update issue resolved*
    Texas
    Switched to a racetronix pump and the pump isn't priming. The one before had stopped and wasn't priming either.
    I have tried with the caspers rewire and the factory wiring and still no luck. The fuel pump fuse is good. What should I check next?
    I will be pulling the pump back out to double check connections, but in the meantime any suggestions?
    85 Corvette
    01 TA
    03 Z06
  2. #2 Re: Racetronix pump installed and not priming?
    Are you getting power from the harness?
    Check with a digital multi meter.
  3. #3 Re: Racetronix pump installed and not priming?
    Texas
    No power to the fuel pump fuse. The relay clicks but the fuse has no power. How would one go tracking down the problem for that?
    Thanks
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: Racetronix pump installed and not priming?
    No power to the fuse or after the fuse?
    Technically these are for a Regal, but they are the same for the GP
  5. #5 Re: Racetronix pump installed and not priming?
    Texas
    Ok fuse has power I didn't hook the meter up right. Double checked it and it's getting power. No power going out of pin 8 of PCM to fuel pump relay. If I apply power manually the fuel pump turns on. What reasons would keep the PCM from turning on the fuel pump relay. Checked voltage at PCM supply and getting 12 volts.
    Tried a 2nd known good PCM and it did the same.
    85 Corvette
    01 TA
    03 Z06
  6. #6 Re: Racetronix pump installed and not priming?
    possible security issue?
  7. #7 Re: Racetronix pump installed and not priming?
    Texas
    I didn't think the 97 had a security feature on it. Any idea how to test.
    85 Corvette
    01 TA
    03 Z06
  8. #8 Re: Racetronix pump installed and not priming?
    Texas
    Anyone?
    85 Corvette
    01 TA
    03 Z06
  9. #9 Re: No power to fuel pump relay from PCM?
    GT Level Member RegalGS98s's Avatar
    NJ
    Fuel pump relays? If you have someone turn the key to on, do you have power at the fuel pump harness for about 3 seconds? Where is pin 8 of the PCM supposed to go? What was the original condition before you changed the fuel pump (Did the pump go out unexpectedly, were you working on something else when it stopped working, etc.)?
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  10. #10 Re: No power to fuel pump relay from PCM?
    Texas
    Copy and pasted from another forum:
    Vehicle in question is a 97 Pontiac Grand Prix GTP. This issue has me scratching my head.
    A little background on the issue:
    Before installing the new fuel pump the vehicle would lose power(like fuel was cutting out). All accessories would still be active. I assumed the fuel pump was going bad as one day I tried to start the car and it wouldn't. Fuel pump wouldn't prime so I ordered a new one.
    Got it installed and was still seeing the same issue. Took the fuel pump back out and double checked everything. It all checked out and went to try again-Same fuel pump won't prime the system. And I have no fuel pressure.
    I began to diag the electrical. First was the fuel pump fuse since it is hot at all times-checks out) Next wents to the fuel pump rewire(bypasses the fuel pump resistor which is a known problem in the GTP's). It's getting the full voltage to and after the fuse all the way back.
    Checked the fuel pump relay and replaced it to be on the safe side.
    I went ahead and forced the pump on manually by giving it power and it kicked on. Tried to start the car and it didn't(haven't checked the fuel filter but that will be later).
    Went back to checking the relay and found that it wasn't getting power at the pins on the fuse panel. No problem let's check the continuetity and power. No power to it at all. Checked for power at the wire off of the PCM and no dice. Went ahead and checked the pin off the PCM and still not getting power. Then checked to see if I'm getting 12 volts at the PCM supply which it is.
    I found out the BCM cuts the fuel signal to the PCM if it doesnt registers, and theft deterant relay does as well.
    Next step was to look at the BCM(body control module) which sends the signal to the PCM.
    No shorts on the pins of BCM. BCM will initialize, but is not sending the 5v pulse for the fuel cutoff. Tried to pcm with same results.
    I also pulled every fuse to see if something is blown and all are showing good.
    The Drivers Information Center is blinking 0. I also have tried using a 2nd known good PCM and it does the same. I even tried hooking a scanner to the vehicle to pull codes and it won't connect with either PCM. I tried the scanner in a different vehicle and it connceted just fine.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: No power to fuel pump relay from PCM?
    Texas
    Going to trailer it to a shop for further diagnostics. I'll post what the issue is incase there's someone else out there who runs in to this same problem. I hate it when cars defeat me.
    Hopefully it will be repaired and I can get back to enjoying the turbo setup.
    85 Corvette
    01 TA
    03 Z06
  12. #12 Re: No power to fuel pump relay from PCM?
    NJ
    Found this searching Google for DIC blinking 0 : http://www.grandprixforums.net/d-i-c...sue-28706.html I thought it sounded like a wiring issue. They're saying check your grounds. Here's another from google: 99 GTP DIC flashing 0's - Car Forums and Automotive Chat
  13. #13 Re: No power to fuel pump relay from PCM?
    Feb 2009
    flintnasty MI
    if you dont have anything coming from the pin on the PCM.. you are in rough shape...
    If you do, just bypass whatever other crap is going on and run it direct to the relay... I do it like that in my fiero and it works fine.
  14. #14 Re: No power to fuel pump relay from PCM?
    Texas
    Quote Originally Posted by RegalGS98s View Post
    I think it's multiple issues. I'm thinking it's a ground, security, and PCM problem. I'm still leaning more towards ignition/theft/BCM though.
    If it is a ground I'm anxious to know which one. In fact that would be awesome if it's a ground=cheaper fix.
    Not going to the track LOL
    85 Corvette
    01 TA
    03 Z06
  15. #15 Re: No power to fuel pump relay from PCM?
    Texas
    Problem is solved. 1 is my stupidity by bending the wrong tab during diagnosis. I bent tab 36 instead of tab 85. *FLAME SUIT ON*
    Next is my awesome PCM that came with the ct turbo kit I purchased from Kuntzie. In laymans terms it's junk and is what's causing the spariodic cutout issue. They're 99.9% sure it's an internal issue. Thanks buddy.
    So to remedy the situation I will be purchasing a tuned PCM from ZZP.
    85 Corvette
    01 TA
    03 Z06
  16. #16 Re: No power to fuel pump relay from PCM?
    Grand Rapids, MI
    Quote Originally Posted by txslow6 View Post
    might not want to get a zzp tune... ask bluegtp91, read his thread, ask members.. you will see.
    perhaps 3800 performance or contact Will at Overkill for a more custome tune.
  17. #17 Re: No power to fuel pump relay from PCM?
    Feb 2009
    flintnasty MI
    97 pcms are a mega*****... I daily drive a 97, and occasionally after I tune it, tons of weird codes come up, and the car runs like a bastard.
    I always have to clear the codes and power cycle a few times for it to run right again sometimes.
  18. #18 Re: No power to fuel pump relay from PCM?
    Texas
    Quote Originally Posted by brandonl2000 View Post
    I'll pass on asking members. I have NEVER had an issue with ZZP or their PCM's. Infact my last GTP put down 271hp/325tq with a 3" dp, 3.4 pulley, plog, 1.9 rockers, SSIC, ZZP 1.0 PCM.
    You guys crack me up. Its like one or 2 members have an issue then all of the sudden. Don't buy from such and such company cause they are terrible.
    85 Corvette
    01 TA
    03 Z06
  19. #19 Re: No power to fuel pump relay from PCM? *Update issue resolved*
    Grand Rapids, MI
    Okay...well just wanted to make sure I put it out there for you. -_-
  20. #20 Re: No power to fuel pump relay from PCM? *Update issue resolved*
    I was reading that and thinking "**** no...." then I saw the SSIC haha.
  1. Installed OEM Nav
    By richhurl in forum Audio, Security & Visual Electronics
    Last Post: 11-06-2010, 08:20 PM
  2. fuel pump? not priming
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-10-2010, 05:47 PM
  3. Fuel pump not priming HELP!
    By ls6velless454 in forum General Tech Discussion
    Last Post: 09-19-2010, 04:45 PM
  4. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
