Thread: Header Install...on a Park Ave Ultra!
Results 1 to 20 of 20
  1. #1 Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    Who's done this? Top or bottom install? tips on doing so?
    I have SD Headers waiting about 2 weeks to go on.
    I know i have a LOT of AC/Coolant related lines directly behind the motor that run into the firewall. I'm not sure if they exist in such a location on the GTP/Regal/etc. At least the coolant (for the heater core) appear to be easily removable but the AC one is sketchy. there's also the engine bracket which seems easy enough to remove.
    Option B is removing the 4 rear cradle bolts and letting it down a couple inches or whatever to install from underneath. I've NEVER done this before so im skeptical at best. Prefer feedback if anyone had gone that route and the steps it took/what you did.
    Since the TB/intake has to come off I also have a ported blower case i plan to do at the same time. Would it be beneficial to remove everything for the blower swap first, then while blower is off install headers, then finish blower? would i gain any room by doing it in that order?
  2. #2 Re: Header Install...on a Park Ave Ultra!
    Not sure where B town is.. but if you are on the east side of the state and want a hand, stop on over.
    As for install.
    Jack and support the car.
    Pull off the crossover at both ends.
    Remove front manfold (might be a 13mm or 15mm holding that shield on the passenger end of the motor under the ...or just above the idler pulley)
    Reach down or get under with an extension and swivel and pull the downpipe and rear manifold out.
    Wiggle rear manifold out the bottom.
    Wiggle new rear manifold in from the bottom.
    Bolt up
    Slide clamps and crossover in
    Start front manifold and wiggle/tap (rubber mallet) on crossover to seat evertyhing.
    Clamp and go drive.
    There's no need to pull the TB, air tube or airbox. It's that easy and that large of a car that you'll have an easy time. No need to drop the cradle in most non-W body cases.
  3. #3 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    B-Town is my affectionate nickname for Bradford. I'm in the NW portion of the state so that's a rather long roadtrip but thanks for the offer
    no need to drop the cradle? this would make me happy in the pants. there is quite a bit of room underneath the park ave but i've never done FWD headers before so i thought i'd post up and see what the deal is with this chassis since the W-body walkthrough makes me sorta cringe.
  4. #4 Re: Header Install...on a Park Ave Ultra!
    I can't guarantee anything. It's not like you posted your year .
    On the 97 Bonne though, I lifted the new rear header into place, reached wayyyy up and threaded the bolts in by hand. There's that much room. On an 00 Bonne we wiggled the manifold and it went in.
  5. #5 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    I sry --- It's a 99
    it's nice to know you didn't have to drop anything. Technically although closely related the Bonne/Park Ave are 2 different chassis but most parts interchange. I'm hoping im ok.
  6. #6 Re: Header Install...on a Park Ave Ultra!
    Well considering we are using w body parts..lol
    OH.. Get a W body transmission dipstick tube. Otherwise you aren't going to enjoy that install at all.
  7. #7 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    needs bent a fair bit from what i can understand.
    is it really that bad?
  8. #8 Re: Header Install...on a Park Ave Ultra!
    If you hit a JY with 2 feet of extension and a universal 10mm socket..you'll have one for cheap.
    The difference is huge and not worth trying to bend your own IMO.
  9. #9 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    any trans dipstick tube from a 97+ GTP or should i match like year?
  10. #10 Re: Header Install...on a Park Ave Ultra!
    97+ GP, Regal, Impala, Monte....only requirement is they have to be a 3.8L. Can be SC or NA.
  11. #11 Re: Header Install...on a Park Ave Ultra!
    PA
    Don't the w-body dipsticks still need bent a little bit to fit these headers?
    2001 GSE
  12. #12 Re: Header Install...on a Park Ave Ultra!
    Only other bending needed would be for TOGS.
  13. #13 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    Perfect. I will hit the local yards for this part. Likely can get it for like 10 bucks.
  14. #14 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    I have an issue.
    my stock stick is toast.
    I bought a stick from a local yard that said it was from "97+ W body"...
    yeah. did not fit. it still hit the dipstick installing the rear header from underneath. i cannot get the header pushed far enough to the drivers side to get on the studs.
    I tried bending this tube. bracket broke off. 2 pinholes in the tube, 4 kinks, and it's all sorts of screwed up.
    I CANNOT afford ANYMORE downtime. I NEED this to work.
    I need a prebent dipstick that WILL clear Speed Daddy/SLP/SSAC headers. It was said the 97+ will work from Wbody but anyone have a pic? Does it look like the one at INTENSE? will that one clear?
    HALP!
  15. #15 Re: Header Install...on a Park Ave Ultra!
    Look where it bolts to the trans. Is the tab rectangular in shape or is it more of a triangle?
    Rectangle is an H/G/C body tube, triangle is W body. Hold the tubes side by side, post up some pics for us. We are blind at the moment.
  16. #16 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    It was rectangular.
    I KNEW somehow they'd find a way to mess that up. i gave specific instructions for 97+ GP, Impala, Monte ONLY. they pulled it from a random 3800 powered car. great.
    It's so mangled it can't be returned so i'm going to have to suck it up as a 10 dollar loss PLUS a day from work. I will call tomorrow and see specifically if they have any 97+ W body cars in the inventory. I know they should but it is not a u pick it yard...all one ones around here are private.
  17. #17 Re: Header Install...on a Park Ave Ultra!
    Oddly enough I don't see any pics of tubes in my pb account.
  18. #18 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    I'd upload some for you though you definitely answered my question. I'm gonna try again today at the yard and if not i will need to order one from a dealer/intense with next day shipping.
  19. #19 Re: Header Install...on a Park Ave Ultra!
    Take your old original (unbent) with you. Hold them up and you'll see the difference immediately near the bottom.
  20. #20 Re: Header Install...on a Park Ave Ultra!
    Jul 2011
    B-Town, PA
    both of them are twapped beyond use/recognition. From what i can tell based on the pic at INTENSE is the bottom has a steeper bend to allow it to clear to the right of the crossover (as viewed from front of car) and as you stated the hold down bracket is triangular. i will look for these cues.
  1. 97 Park Ave Ultra LOUD supercharger noise
    By RustyCage in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2011, 09:03 AM
  2. TOG header install
    By 2001goldGTP in forum General Tech Discussion
    Last Post: 12-16-2010, 11:17 AM
  3. Changing belt on 1997 Buick Park Avenue Ultra
    By joshua_arndt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2010, 12:39 AM
  4. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  5. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
