Thread: gas filler neck
Results 1 to 5 of 5
  1. #1 gas filler neck
    SE Level Member gpgt98's Avatar
    Jul 2010
    Michigan
    Can anyone on here help me on how to remove the gas filler tube? Mine is getting pretty rusty. I got as far as getting it unbolted but I can't get the plastic piece behind the gas door out to remove the tube.. just wanna inspect it as it seems I'm going thru gas really fast lately.
  2. #2 Re: gas filler neck
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    just replaced mine --- that plastic thingie is held in with 5 screws, the four you see when you open the gas door and then one by the hinge. you have to remove the frame attachment point to push the filler tube back a little, once you do the plastic deal will drop out.
    I got a pristine one at the boneyard for $15 and included the plastic deal you're messing with. the one I took out was a rusted mess. I don't think it was leaking fuel but I know it was gassing fumes and not holding vacuum.
  3. #3 Re: gas filler neck
    Jun 2011
    Detroit, MI
    I was just thinking about why my gas is going quick too on the G6. I think it really is just the A/C.
    iLoveSpade
  4. #4 Re: gas filler neck
    GT Level Member neel2008's Avatar
    Huntington, IN
    I would hope a G6 isnt rusted out yet.....then again you are in Detroit, so im sure it is even worse there then it is here lol
    97gtp
  5. #5 Re: gas filler neck
    Jun 2011
    Detroit, MI
    No, no rust anywhere, just saying that gas goes alot quicker in the summer from the heat/AC
    iLoveSpade
  1. Oil filler neck removal?
    By TheMayor937 in forum 5.3L V8 (LS4)
    Last Post: 02-26-2011, 08:13 PM
  2. water in oil filler neck
    By m1sterb0b in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2011, 02:07 PM
