Thread: 05 GTP Electronic Problem
Results 1 to 5 of 5
  1. #1 05 GTP Electronic Problem
    Jun 2011
    Columbia
    Good morning,
    I have a 2005 Grand Prix GTP and occasionally when I put the key in and turn it to 'Start' the car electronics will 'reset' (all the lights go out, when let the key goes back to 'Run' they come back on). Most of the time after a couple attempts the car will finally start. I had the battery checked and charged, the Voltage gauge is listing about 14.xx volt.
    I'm not sure where to go in attempt to troubleshoot this problem. Key switch? Battery? Starter?
    Thank You!
    Adam
  2. #2 Re: 05 GTP Electronic Problem
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    I don't know for sure, but my guess would be the key switch. Possibly a bad start contact or something to that effect.
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  3. #3 Re: 05 GTP Electronic Problem
    Jun 2011
    Columbia
    That was my first guess, as today I also giggled the key a little and it seemed to cause the car to work today.
    Is that difficult to replace? It is the in-dash style.
  4. #4 Re: 05 GTP Electronic Problem
    Jun 2010
    Christiansburg, VA
    I know that it's easy to get to. Simply pop the black ring around it off with a flat-tip, then the center bezel with the DIC pulls off (gently!). I'm not sure if any special tools are required to get the key cylinder itself out.
  5. #5 Re: 05 GTP Electronic Problem
    Kansas
    I'm not for sure but you might have to change some stuff in the BCM as well.
  1. Electronic Gremlins
    By Joe Limon in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2010, 08:43 PM
  2. Electronic Connections
    By Ibwrong in forum General Tech Discussion
    Last Post: 12-17-2009, 06:41 PM
  3. electronic dist
    By HARLEYBAYO in forum Introductions/Noob Questions
    Last Post: 11-18-2009, 12:15 PM
  4. Electronic Cutout!?!?!?
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 08-06-2009, 08:12 PM
