Thread: 98-03 Gtp vs 2004+ Gtp
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: 98-03 Gtp vs 2004+ Gtp
    Drive by wire is the term used for electronic throttle control.
    a cable has instantaneous throttle response.
    A wire must rely on ADC's and DAC's as well as a computer to open the throttle.
    Not saying you'll notice the difference.... but I am say you wont notice the difference in throttle response.
    The fueling isn't controlled by the throttle plate, but rather the MAF and O2 sensor.
    And any fuel economy gains will be negated by the extra 200 lbs you have to lug around.
    Quote Originally Posted by 01gpgt01 View Post
    NONE are forged. There powder coated
    Swan racing's are....
    Feb 2010
    tampa
    and they have the aluminum upper intake, not upgrading the older car is easier, but older cars are always easier to upgrade naturally
    what color
  3. #43 Re: 98-03 Gtp vs 2004+ Gtp
    stop making 10723019823091231231 posts.
    use the edit button.
  4. #44 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2010
    tampa
    yes but deoending on how much you open the throttle tells the computer how much fuel oxygen to let in. electronics will alwaays be more acurate then a wire. hence the car becomes more efficient.
  5. #45 Re: 98-03 Gtp vs 2004+ Gtp
    Quote Originally Posted by wking2 View Post
    Ask someone who tunes.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Powdered metal is more durable and reliable than conventional cast iron, delivering greater anticipated life. As importantly, the powdered metal rods are stiffer than the cast iron parts they replace.
    Wire you mean cable? drive by wire Vs cable just boils down to throttle response. The maf controls fueling. I fail to see any pionts here
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  7. #47 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2010
    tampa
    maf and throttle are all tied together is my point lol
    people will forever argue over this. You can find people, who believe in electronic and some will believe in the old way
  8. #48 Re: 98-03 Gtp vs 2004+ Gtp
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    i REALLY don't understand this thread.
    There are still reasons not to buy the 04+ like secondary AIR system, 200 lbs more curb weight, cost, 04/05 require a change of LCA's to upgrade sway bars.
    But quit caring so much and look at whats available in your area for what you're willing to spend.
    In the end thats what matters, what pleases you.
    What AIR system?
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  9. #49 Re: 98-03 Gtp vs 2004+ Gtp
  10. #50 Re: 98-03 Gtp vs 2004+ Gtp
    Not a valid point...the MAF isn't in the throttle body in the '04+ cars like in the '97-'03.
    Mooooooooot.
    It also has nothing to do with the throttle...as the TPS controls that.
  11. #51 Re: 98-03 Gtp vs 2004+ Gtp
    utah
    pretty sure only the cali cars had secondary air......
  12. #52 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2010
    tampa
    yes, just for cali cars and i think only under cold operation does it kick in.
  13. #53 Re: 98-03 Gtp vs 2004+ Gtp
    yea because the blower is better on the 04, and the engine is a little stronger. with less boost you get more power on the 04 and up. thats why a lot of 97-03 guys want m90 superchargers, there much better.
    Um the 97-03 had M90s too just a different version. Series II 3800 had a Gen III Eaton M90 supercharger the Series III 3800 had a Gen V Eaton M90 supercharger.
  1. 2004+ gtp fwi
    By donkason in forum General Tech Discussion
    Last Post: 09-26-2010, 12:41 PM
  2. 2004 gtp
    By krazy3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2010, 08:41 PM
  3. 2004 gtp abs
    By justmebobg in forum Introductions/Noob Questions
    Last Post: 07-05-2009, 12:52 PM
  4. 2004 gt
    By green mountain goat in forum Introductions/Noob Questions
    Last Post: 06-16-2009, 05:43 PM
  5. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
