Thread: Rad Options.
Results 1 to 20 of 29
  1. #1 Rad Options.
    2002 GP GT, few mods.
    I seem to be having issues keeping my coolant temps down on hot days (90+).
    Stock GT rad, 180 thermo, tight fan settings, etc.
    I see ZZP's option but i'm not a fan of buying and shipping such a large item.
    Other than the GTP rad, there seems to be the 1998 Monte rad as per: http://www.grandprixforums.net/radiator_upgrade.php
    Locally all I can find is the 1" rad. (still an upgrade from my 5/8ths core)
    Now with the trans cooler fittings my understanding is they'd be different thus requiring new ones.
    Since my lines are starting to seep I was tossing around the idea of a standalone fluid cooler with SS lines and AN fittings and skipping the stock cooler.
    Another option is to roll down the windows, turn off the a/c, turn the heater on max. That seems to work, at the cost of sweaty clothing.
    Thoughts?
  2. #2 Re: Rad Options.
    Go with the sweaty balls option.
  3. #3 Re: Rad Options.
    Sweaty Canadian is a bad smell.
    Your fans are working 100%?
  4. #4 Re: Rad Options.
    I believe so. Will check again.
    Also tried cleaning the fins out with compressed air.
  5. #5 Re: Rad Options.
    Is it tuned?
    What are the fan turn on points set at? Also...FWIW, after I did the LIM gaskets, flushed the dexcrap out...tossed in a 180* and got it tuned...it never goes above the first big line...ever. Maybe your car hates you a lot? It is a Canadian GP afterall.
  6. #6 Re: Rad Options.
    Will has tuned it a number of times.
    Low speed comes on at 180F, off at 176F (basically set on all the time when the thermostat starts to open) but low speed is disabled over 45mph and reenabled under 40mph.
    High speed comes on at 189F and off at 185F and is available at any road speed as needed.
    So cruising around at 194/195 certainly raises an eyebrow.
  7. #7 Re: Rad Options.
    Looks like your rolling a 195 stat to me. Got a pic of the bottom of the one you put in to verify it?
  8. #8 Re: Rad Options.
    Cruising at 185 all day today.
    68* F was the ambient according to my car.
    Weather network claims 64.
  9. #9 Re: Rad Options.
    Is that in Farenheit or Canuckian? you know.. C or F?
  10. #10 Re: Rad Options.
    All units are F.
  11. #11 Re: Rad Options.
    I bet you got a 195*...from you and Nick's 195* tangent you both went on.
  12. #12 Re: Rad Options.
    dunnn make no sense brah.
    Guess i'll warranty it then.
    Lifetime warranty on t-stat? Oh yes...
  13. #13 Re: Rad Options.
    Dec 2008
    Lawndale, CA
    I ended up replacing my stock GT radiator with a GTP radiator from rockauto. I got the spectra one. It shipped with no damage to the radiator. Everything was in good shape when I opened it. I ended up using whatever hardware that came with the replacment. Everything fit with no issues. Just be sure that your tans lines are tight so they don't leak.
  14. #14 Re: Rad Options.
    The boarder likes to charge money for international shipping.
    And more money if they feel the need to inspect the package.
  15. #15 Re: Rad Options.
    I'd be willing to bet your tiny radiator + all the extra heat your making from boost isn't helping either. Especially since intercoolers HELP SO MUCH.
  16. #16 Re: Rad Options.
    Wasn't a problem last season with the 3.8.
    180-183 under normal conditions, 185 max.
    This season with the 3.4...
  17. #17 Re: Rad Options.
    Almost double the boost fool
  18. #18 Re: Rad Options.
    actually no.
    previous was 5-5.5 at 4000 RPM, now its 6.5-7.
    previous was 7 max, now 9 max.
    Only just now did i see the ""...
  19. #19 Re: Rad Options.
    Bunnell, FL
    I'm a Sex Offender
  20. #20 Re: Rad Options.
    I'm not paying for shipping, and no warranty to save $20.
  1. 08 GXP strut options
    By looong4 in forum Brakes/Suspension/Chassis
    Last Post: 02-08-2011, 12:42 AM
  2. TB and MAF Options ?
    By Lawngoose in forum General Tech Discussion
    Last Post: 08-23-2010, 07:59 PM
  3. 2 options.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-27-2010, 12:27 AM
  4. TB options
    By 4drgt in forum 04+ Specifics
    Last Post: 09-12-2009, 03:14 PM
  5. What are our options?
    By gdbyrd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2009, 12:17 AM
