Thread: Autometer boost gauge problems
Results 1 to 19 of 19
  1. #1 Autometer boost gauge problems
    Jun 2011
    Alberta
    I fail to grasp what i found on the internet, and
    understanding the people on automotiveforums.com
    I first installed the T where it is showed on the web,
    i had nothing happen on my gauge, than found a guy
    that took a picture of his where it was T'd closer to
    the windsheild, i did that as well, and again nothing.
    I dont understand what my problem could be >.>
    I was also told from a mechanic that i should be
    connecting it on something close to the throttle
    body?
    Ill post a picture of the 2 areas
  2. #2 Re: Autometer boost gauge problems
    Omaha, NE
    Use the outlet side of the supercharger, where the map sensor is, then run the line through the firewall to your gauge.
  3. #3 Re: Autometer boost gauge problems
    Jun 2011
    Alberta
    LOL i have the hose run to the gauge in the car connected to the pod and
    ready to go, i have the hose T'd into the hose that goes from under the snout
    to the back of the engine
  4. #4 Re: Autometer boost gauge problems
  5. #5 Re: Autometer boost gauge problems
    Omaha, NE
    And your needle just isn't moving, or..?
  6. #6 Re: Autometer boost gauge problems
    Jun 2011
    Alberta
    My needle is not moving at all, i let the car run and i took the hose
    from the back of the gauge, all i get is a suction coming from it.
    also i cant seem to figure out how to post a picture so ill try uploading
    them to a site
  7. #7 Re: Autometer boost gauge problems
    Jun 2011
    Alberta
    Just so you know i have to improvise cause
    apparently there is not much material to go
    with unless i order off the web
  8. #8 Re: Autometer boost gauge problems
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Kairocross View Post
    them to a site
    your supposed to have suction on the gauge at idle
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: Autometer boost gauge problems
    Omaha, NE
    Which gauge do you have? That might help.
    If the hose is kinked anywhere it won't have enough vacuum or boost to move the needle like it should.
  10. #10 Re: Autometer boost gauge problems
    Jun 2011
    Alberta
    Ive driven my car on the highway and even pinned it a few times
    nothing happened to my gauge.
    I checked before and theres no kinks at all.
    My gauge is a Boost 0-35psi Autometer ES series,
    i can find the model number or link to it if you like
  11. #11 Re: Autometer boost gauge problems
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Hm, sounds like your gauge MAY be defective. I have the same gauge and have it hooked into the same T fitting below the snout and im reading 18 vac at idle and plenty of boost at WOT. Send it back in to AutoMeter or just take it back to where you got it and get an exchange.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  12. #12 Re: Autometer boost gauge problems
    Omaha, NE
    It's a boost only gauge, that's what I was looking to know. It looks like the gauge is right, so lets look at some other options.
    Do you have any vacuum leaks that you know of or any other possible reasons you may not be hitting boost?
  13. #13 Re: Autometer boost gauge problems
    Jun 2011
    Alberta
    Auto Meter
    I havent tryed the (spray soemthing on to see bubbles) idea yet, but from
    what i seen i am pretty sure there wouldnt be any leaks, i made sure the hoses
    were tightly fitted than zit tied most of the ends.
    My engine has alot of km on it so maybe my SC isnt working? i dont know what to
    really think of
  14. #14 Re: Autometer boost gauge problems
    Atlanta, GA
    Well you said that you felt slight suction from the tube connected to the back of the gauge which means that you atleast have SOME vac and you also said that there is no reading from the gauge AT ALL which leads me to believe the gauge is bad. And youd know if your SC wasnt working... trust(I hope)
  15. #15 Re: Autometer boost gauge problems
    Omaha, NE
    I would try another gauge if you know someone that has one.
  16. #16 Re: Autometer boost gauge problems
    Houston
    If you have access to an air compressor, I'd take the gauge out and turn the psi up to about 10 or so on the compressor. Connect it to the gauge and see if you get a reading.
  17. #17 Re: Autometer boost gauge problems
    Jun 2011
    Alberta
    LOL i can still hear my SC when i punch it and it still has
    a strong pull, but the suction isnt light, its a pretty good
    and constant, but it is only sucking, and like i said my
    gauge doesnt read any vac, i didnt know about that till
    after i bought a plain Boost only gauge
  18. #18 Re: Autometer boost gauge problems
    Jun 2011
    Alberta
    that sounds like a good idea, ill get my brother to help
    me after the hockey game, if not ill try it first time tomorrow
    after work. really hope its not a faulty gauge since i dont
    have the box or reciept anymore
  19. #19 Re: Autometer boost gauge problems
    Jun 2011
    Alberta
    sorry for the multi posting, dont know if that is bad on these
    forums, but i wont beable to test the gauge till after work
    tomorrow
  1. boost gauge problems
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 12:21 AM
