Thread: DIC HVAC gone..
Results 1 to 11 of 11
  1. #1 DIC HVAC gone..
    ATX
    well i guess the cars pissed im trying to sell it, because now the HVAC and DIC are glitching..
    Heres whats going on, yesterday after starting the car the AC and DIC hesitated for about 30 seconds before turning on, then again it was about 2 mins before it turned on.
    Now today neither would turn on, so i unhooked my amp and sub setup thinking it was draining to much power.. Well the fuse is getting spikes around 4v to 7v and aslong as the HVAC is set too off the DIC will flicker a few times, then turn on and stay on. But any attempt to turn the HVAC on kills the DIC.
    HVAC works on setting 5 and the compressor is coming on and blowing cold air. But still wont let DIC come on, and it hesitates about 10 to 15 seconds before HVAC works on setting 5.
    haaaalp.. im lost on this one, is my BCM just dying off some more? the BCM is already faulty and won't let the interior lights work.
  2. #2 Re: DIC HVAC gone..
    Never Never Land
    sounds like a ground issue to me...but if the BCM is already a known problem it could be that too.
  3. #3 Re: DIC HVAC gone..
    ATX
    well if it was a ground issue wouldnt the DIC always flicker? once it like builds up enough power it stays on.
  4. #4 Re: DIC HVAC gone..
    Never Never Land
    it may be randomly be grounding and ungrouding itself causing it to work sometimes but not others.
  5. #5 Re: DIC HVAC gone..
    GT Level Member Tea Time's Avatar
    New Brunswick
    DIC' s SUCK! i have 2 gtp's and neither dic work ...check the wire harness in the engine bay that runs around the a/c condenser to verify that its not chaffing and shorting out.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  6. #6 Re: DIC HVAC gone..
    Never Never Land
    FWIW my DIC's lights would randomly flicker...replaced the bulbs and its been fine ever since.
  7. #7 Re: DIC HVAC gone..
    New Brunswick
    I've got a thread on DIC's not working, i haven't resolved my issue yet (cuz i'm lazy) but another guy fixed his dimming dic by doing an "ignition saver mod"....fwiw, i hacked my ignition harness apart for that fix and it didn't work for me.
    Where the op's problem is both dic and hvac, it shouldn't be too hard to find the issue should it be shorting out or grounding poorly
    '97 GTP - Project
  8. #8 Re: DIC HVAC gone..
    ATX
    k just noticed this, in park with the blower motor set too off, the light of the AC compressor is on. its not resposive to turning it off with the button, i have to set the AC controls to the notch above MAX.
    If i try and turn the blower motor on, the AC Light turns off and the headlights dim very bad, but if i put the car in drive they light up all the way..
    what... the... ****
  9. #9 Re: DIC HVAC gone..
    Never Never Land
    im gonna have to say BCM
  10. #10 Re: DIC HVAC gone..
    SE Level Member jmt455's Avatar
    SE Michigan
    Mine did the same things. It was the ignition switch.
    All OK after replacing it.
    83 Bonneville wagon
    08 G8 Base
  11. #11 Re: DIC HVAC gone..
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I wasn't aware that the BCM had any control over the HVAC system. Someone please correct me if I'm wrong.
  1. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  2. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  3. HVAC problems
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 01:53 AM
  4. looking for the hvac features
    By 03impala9c1 in forum General Tech Discussion
    Last Post: 11-15-2009, 06:59 PM
  5. 04 hvac
    By Scott Francis in forum Introductions/Noob Questions
    Last Post: 10-16-2009, 03:36 PM
