I got on my gtp a while ago and turned the car on and i have no power going to my DIC, Radio or A/C!!! What would cause this? I think it might be a ignition switch harness but not sure. Anyone had this problem before
yea my home-e badaz is right
Don't know if I'm right yet or not. Just wanting to know if all the basics have been checked first. Got to remember to start with the simple stuff and work your way to the hardest.lol!!
Moved this to the right section.
I would first check all the fuses as suggested. It does sound like it could be an ignition switch issue, but check the fuses first. Does the A/C fan work on any speeds at all?
if you pull the cover off the column there is a black box, squeeze it if everything comes on you need the switch (or epoxy that like I did)
Yes ive checked all underhood fuses and dash fuses... the a/c fan dose not work at all
Then that should take you to the next thing, which it gets it's initial power from, like said before, ignition switch. Try what archemedessaid and let us know what you find.
10-4.....will do. See what I can find out tomorrow(if it dosent rain).
Yes, car starts and drives as strong as the day I bought it... just no a/c dic or radio
I lost all of that driving once, and it was from the box in the column
The box on the column was the prob, and yes J.B. weld was my friend lol. Everything's working as it should! Thanks to you all! Big thanks to Archemedes
glad it's fixed
