Thread: car rattles after cam install then wont start at all!
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: car rattles after cam install then wont start at all!
    Bastard Reptile's Avatar
    Kansas City, MO
    Have you pulled the plugs? When you say valve float, you're worrying me here....you could have slapped a piston with a valve.
  2. #22 Re: car rattles after cam install then wont start at all!
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Hate to say it but you might have some bent valves
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #23 Re: car rattles after cam install then wont start at all!
    Kansas City, MO
    Quote Originally Posted by Toofastgs View Post
    That's what I'm thinking too. Putting a cam in without doing the springs, and then raising the shift points past 6200 you're pretty much asking for trouble.
  4. #24 Re: car rattles after cam install then wont start at all!
    Donating Users chrisb's Avatar
    Bucyrus, OH
    well engine has some metal shavings in the pan and we cant turn it over so looks like a new motor. my shift points were at 6k were tearin it down now to see what the promblem is.... i might just get rid of all my modds. its getting to be to much with just buying the slps headers,hptuners pro, and the laptop...not sure if i can do this anymore thanks guys for all the help.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  5. #25 Re: car rattles after cam install then wont start at all!
    Bucyrus, OH
    well looks like i spun number one! how nice oh well i think im going to put in new rings and bearings in now. not sure if i should just get a shortblock or crank and new rod.
  6. #26 Re: car rattles after cam install then wont start at all!
    TDCRacing
    Guest
    Hmmm...so the ballancer was ok? Any way lol you should definetly do a compleate rebuild on it. New cam,Crank and rod bearings. Line hone it before you put a new crank in it for sure.And also hone the cylinders with a torque plate and put new rings on the pistons. shoot may as well buy a forged rebuild kit. You already have a short block so why would you buy a new or used one? just rebuild the one you have. Just my .02
  7. #27 Re: car rattles after cam install then wont start at all!
    Kansas City, MO
    That's what happens when coolant gets into the bearings. sux
  8. #28 Re: car rattles after cam install then wont start at all!
    Bucyrus, OH
    well the balancer im not sure on it looks like it wobbles when it runs when i put a new one on the car wouldnt even start!.... i think the whole timing to be out was caused by the knock sensors picking up the noise from the spun bearing and thinking it was kr. what is line honing? i planned on having the cylinder walls done with new rings and bearings. as far as forged internals....im only n/a right now so that might be a bit over kill. i didnt look like any coolant in the oil but i kno some got in it before we started it up but we changed it out soon after. couldnt dirt cause a bearing to be spun?
  9. #29 Re: car rattles after cam install then wont start at all!
    TDCRacing
    Guest
    Quote Originally Posted by chrisb View Post
    yep. a grain of sand can do wonders
    what is line honing? Line honing is when the make sure the mains (where the crank bearings are at) are perfectly straight. Then they put new bearings in. wether they have to be oversized or not just depends.
    didnt realize you were running N/A so yeah forged would be over kill.
    http://www.youtube.com/watch?v=JrjgjSur1DI
  1. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
  2. Car wont start....mmmm Help!!
    By GeddyLee in forum General Tech Discussion
    Last Post: 02-28-2008, 09:00 PM
  3. p1626 & 1610 code wont start help!!!
    By nvsridez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 11:53 AM
  4. Car dead, wont start !!FIXED!!
    By Maybe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2008, 11:27 PM
  5. 97 blower motor wont fit a 99
    By ryangtp89 in forum General Tech Discussion
    Last Post: 01-01-2008, 12:14 AM
