Thread: Wheel Hub Bearings??
Results 1 to 10 of 10
  1. #1 Wheel Hub Bearings??
    delaware
    Hey, I have to replace my bearings over the weekend. What is the torque value for the bearing nuts?
  2. #2 Re: Wheel Hub Bearings??
    Florida
    GM spec is 159ft/lbs. But if it says different on the new hub, go with that.
    Or just push the ever loving hell out of your breaker bar.
  3. #3 Re: Wheel Hub Bearings??
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Bearing nuts? Are you talking about the bolts to hold the bearing in the aluminum casting?
    The axle nut is 180 ft. lbs. if you're talking about that. It's the important one since too much torque puts undue side load on the roller bearing.
  4. #4 Re: Wheel Hub Bearings??
    Ohio
    I changed those suckers 3 times on my '03. 2 faulty sets and one pot hole. FML
  5. #5 Re: Wheel Hub Bearings??
    Mercer, Pa
    Quote Originally Posted by Crysalis010 View Post
    180.
    They were made in china. Buy good made in USA ones or get lifetime warranty!
  6. #6 Re: Wheel Hub Bearings??
    Pasadena, CA
    I'm having problems with my ABS activating and TCS light sometimes coming on at slow speeds, especially with the wheels turned. Had a coupon for a free service at the local former Pontiac dealer, and they told me the left front hub was worn or damaged, causing the speed sensor to short out and trigger the ABS.
    Questions: 1) Dealer didn't cite a part number; are we talking about Timken 513179? 2) The car has 123,000 miles, and these have never been replaced. Is it worth doing both, or should I just replace the bad side?
    Thanks,
    Eric
    2002 GTP - 123K miles
  7. #7 Re: Wheel Hub Bearings??
    if one is bad the other is sure to follow, its 9 years old, i would do both, why get dirty 2 times.
  8. #8 Re: Wheel Hub Bearings??
    Mercer, Pa
    I bought timken made in usa. I replaced both. Car has 176000 miles but I haven't done hback.
  9. #9 Re: Wheel Hub Bearings??
    Apr 2009
    Quote Originally Posted by sseilmnop View Post
    The problem has been found.
  10. #10 Re: Wheel Hub Bearings??
    SE Level Member crysalis's Avatar
    Mentor, OH
    Believe it or not, they were Timken. Even got a set directly from the manufacturing plant (they are about an hour from me). They were all under warranty except the first set, but I still had to replace them.
    PS... I'm not the OP :P
  1. Wheel Bearings?
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2010, 08:05 PM
  2. Wheel Bearings
    By JAllegar in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2009, 02:57 PM
  3. wheel bearings
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 06-11-2009, 02:45 AM
  4. Wheel Bearings
    By Dangerous313KidInAPrix in forum General Tech Discussion
    Last Post: 02-26-2009, 02:17 AM
  5. Wheel Bearings/Hubs
    By bcrosby51 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:49 PM
