Thread: How do I remove the vacuum lines from fuel pump?
Results 1 to 5 of 5
  1. #1 How do I remove the vacuum lines from fuel pump?
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    The fuel pump in my 02 GTP is going so I bought a new one. So i was wondering the best way to get the vacuum lines off the old fuel pump and on to the new one?
    Thank you
  2. #2 Re: How do I remove the vacuum lines from fuel pump?
    Taking a look at it. You'll see that two should have a white clip inside them. Push the line toward the pump and squeeze the white clip then pull the line off. Should come easily. The other is an oval and simply needs to be squeezed into a circle and it'll pull off.
    The only tough part with these clips is the limited room. Once you get past the room issue..they are easy.
  3. #3 Re: How do I remove the vacuum lines from fuel pump?
    May 2011
    Tampa FL near USF
    thank you
  4. #4 Re: How do I remove the vacuum lines from fuel pump?
    Vancouver, WA
    Sorry for bringing this from the dead but what is the middle line with the plastic O ring you have to squeeze? I recently changed my fuel pump and now have the code P 0440 coming up. Idk if I got that line on right or all the way, trying to figure out if that's my problem. Thanks.
    Slowest 'Cooled Gen V ever
  5. #5 Re: How do I remove the vacuum lines from fuel pump?
    That is likely the evap line and reason for the code.
  1. vacuum lines
    By Danbo004 in forum General Tech Discussion
    Last Post: 04-15-2011, 10:51 PM
  2. Vacuum lines
    By rtorres422 in forum Shops and Community Heroes
    Last Post: 05-24-2010, 10:18 PM
  3. vacuum lines
    By shawn3091 in forum General Tech Discussion
    Last Post: 01-11-2010, 10:15 AM
  4. Different Vacuum Lines...
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-17-2009, 12:47 AM
  5. Identify vacuum lines etc...
    By nmgadb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 12:52 PM
