When im on the highway my rpms will go up & down between 1000 and 2000 even if my foot stays on the gas...does anybody know what could cause this?? It just started today while driving to work and has never happened before.
So the tach is bouncing, but how does the car run? Any different or it runs fine while its doing this?
Well, i only feel the difference when it jumps up...the car kinda accelerates & then when the tach jumps down the speed just evens out to the amount of pressure im putting on the gas pedal..guess u can say it evens out. Not a big difference tho...car dosent chug or anything.
I wonder if the CPS is starting to go? Usually the tach just bottoms out before the engine shuts down, but I guess an intermittent signal would do this.
It is the common fluctuating rpm condition that is caused by one of the sulenoids on the tranny. Mine has had the problem since I purchased it. Check tep's site
mine does it...never throws a code. However you should be able to feel it jerking. If you can't and it's fluctuating a whole 1500 rpms then I think it would point more toward a CPS. Does your tach ever just die?
