Thread: lift points
Results 1 to 20 of 25
  1. #1 lift points
    Jun 2010
    ohio
    does anyone know where some good floor jack points are for an 03 grand gtp i refuse to use the pinch welds
  2. #2 Re: lift points
    Front and rear subframes are my friends
  3. #3 Re: lift points
    Jun 2010
    ohio
    Where is that more inward of the car?
  4. #4 Re: lift points
  5. #5 Re: lift points
    Charles City, IA
    Its the big solid looking piece that looks like it would hold the weight of the car.
    SMGPFC Two Nipple General
  6. #6 Re: lift points
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    whats wrong with pinch welds....
  7. #7 Re: lift points
    Quote Originally Posted by Taz Magester View Post
    i always used the pinch weld to get it high enough to get a jack under the front, but the pinch welds arent recommended (per me) and here is why:
    notice how people say they have saggy doors that hit the fenders when opening and closing? part of this is lifting up from right behind the front wheels on the pinch weld and tweaking the fender. live and learn.
  8. #8 Re: lift points
    and plus the strip that the pinch welds are made from get bent and makes the bottem line under the door look like crap
    SMGPFC Member #10
  9. #9 Re: lift points
    Subframe...like Bill said.
  10. #10 Re: lift points
    lower your car and no one will ever see it.
  11. #11 Re: lift points
    yea i know i plan on it but thats for the ones who dont want to lower theres
    SMGPFC Member #10
  12. #12 Re: lift points
    Charles City, IA
    I have to use the pinch welds to get my car off the ground, cant reach anything else with the jack.
  13. #13 Re: lift points
    Dec 2010
    Ohio
    but the pinch welds behind the wheel was designed to be a lift point and as far bending it goes its almost impossible on that section just take your time and center it up and the problem I have with the sub frame is if your lifting your car to work under it and you put the stands on the sub frame there goes like half your room
  14. #14 Re: lift points
    Clearly you guys need some better tools, better jacks and then you'll be all set.
    I can lift a car high enough to get a trans out with one of the jacks I have. It's low profile and fits under the front air dam of anything I've tried to date. (lots of cars come through here).
    Depending on what you do.. you need to support by the pinch welds. If you are worried about bending the pinch weld or your fenders start to have issues, the car is compromised structurally and should be scrapped or sold. Those pinch welds are designed to be the strongest part on the car, that's how they are lifted at dealerships.
  15. #15 Re: lift points
    Charles City, IA
    I have a craftsman professional jack, I am looking into a low pro jack now that i am lowered.
  16. #16 Re: lift points
    Ohio
    drive your front wheels onto a piece of wood or concrete slab to raise the car another two inches or so and voila! you can get your jack under
  17. #17 Re: lift points
  18. #18 Re: lift points
    Ohio
    haha do it...bill can
  19. #19 Re: lift points
    Anyone that wants to test the jack etc. PM me for an address and start driving east.
    PS I have the Arcan XL35R
  20. #20 Re: lift points
    there is no way in hell even a slim low profile jack will get under my car. the rear, sure. the front, nope.
  1. Hood Lift Support
    By UCF04GPGTPCompG in forum General Tech Discussion
    Last Post: 12-30-2011, 12:07 PM
  2. Pontiac Lift Kit???
    By buckshot in forum Introductions/Noob Questions
    Last Post: 04-04-2011, 09:19 AM
  3. 02 Air Lift Suspension
    By Hawkins97 in forum Brakes/Suspension/Chassis
    Last Post: 07-25-2010, 11:13 PM
  4. Anyone here lift?
    By Panzer4 in forum Off Topic Discussion
    Last Post: 06-24-2010, 05:21 PM
  5. Got Lift?
    By Reptile in forum Off Topic Discussion
    Last Post: 11-24-2008, 03:04 AM
