Thread: Engine Bay Fuse Box
Results 1 to 6 of 6
  1. #1 Engine Bay Fuse Box
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    I have the fuse box removed from the engine bay with all the fuses and relays out. How do I seperate the two halves. I'm going to add some more circuits into the fuse box so I need to sepearte the two pieces to do this.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  2. #2 Re: Engine Bay Fuse Box
    Oklahoma
    Do you mean pull off the connectors?
  3. #3 Re: Engine Bay Fuse Box
    Schaumburg, IL
    I figured it out, you have to remove the 3 bolts/nut design and basically hammer them out. You really have to hit it hard numerous times as the flared end of the bolt/nut design basically stretches the plastic until it gives and then it pops out.
    This isn't my pictures, it was somebody on clubgp that I saved a while back.
    Anyone know where to get those metal clips that basically allow you to put the fuse in.
  4. #4 Re: Engine Bay Fuse Box
    Oklahoma
    Glad you figured it out. Ive never really thought of pulling that sucker apart. Though, if you are adding in a new circuit, I guess its the ideal and stock way to go. Not bad at all, good work.
    As to where to find the pins, that might be a challenge. I havent seen anything like that on the Delphi site or Mouser. If you see Toasty around you might ask him or send him a PM, he would be about the only one that comes to mind that might be able to get you in the right direction. If you do find a source I would appreciate it if you would post that up for others. I might have to look into doing this myself for a few things Id like to add.
  5. #5 Re: Engine Bay Fuse Box
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i cant say that i've seen those peices either. perhaps the best way to get some would be to get a spare fuse box??
  6. #6 Re: Engine Bay Fuse Box
    SE Level Member dave mc's Avatar
    Dec 2008
    milwaukee wi
    I can pull some out of a parts car for you if your still looking just pay the shipping.
  1. how to paint your engine cover, fuse box, plastics [*]
    By kyle99gtp in forum How To Write-Ups/Tech Tips
    Last Post: 07-09-2010, 01:28 AM
  2. I painted my coils and fuse box cover
    By Preotic in forum Visual/Body Modifications
    Last Post: 02-22-2010, 01:13 PM
  3. S/C cover and fuse over
    By JCG's-GTP in forum Off Topic Discussion
    Last Post: 05-28-2008, 04:10 PM
  4. Interior Light Fuse Blows....
    By hester21289 in forum General Tech Discussion
    Last Post: 03-12-2008, 08:02 PM
