here is what was printed out verbatem:
vehicles have one or more of these components. Engine load or the air volume entering the engine measured by these components. The computer has recognized a return signal error.
Probable cause
1.-vacuum hose off, cracked, or passage blocked
Engine mechanical timing condition
2. throttle body intake tube loose, off, or cracked
3. map defective
4. maf dirty or defective
what i have trouble shot so far
replaced vacuum lines and triple checked these and did the wd-40 trick to pinpoint a vacuum leak- ok
has aluminum intake tube, and checked the tube fitting for the throttle body and is on tight- ok
replaced maf already with no change and checked the voltage at the maf-ok
so could be a vacuum line still, or the map sensor
