Thread: antenna leaking?
Results 1 to 3 of 3
  1. #1 antenna leaking?
    SE Level Member mikeplan14's Avatar
    Apr 2011
    Indiana
    Got an antenna, i think, leaking on an '04 GP. Most times that we get a hard rain, some water will tends to come through between the overhead light when driving the car the next time. The gasket on the base of the antenna seems good.. and i pulled the headliner and tightened the antenna. Could this be caused by something other than the antenna? Or any good solutions? I haven't went as far as caulking the antenna yet...
  2. #2 Re: antenna leaking?
    Banned
    Sioux Falls, SD
    Do u have a sunroof? If so when u had the headliner down did blow pressureized air through the drain lines that are on all 4 corners of the sunroof ?
    sometimes they can get plugged.
  3. #3 Re: antenna leaking?
    Apr 2011
    Indiana
    Yup - checked the drain lines before attacking the antenna, but they flowed just fine
  1. antenna removal
    By beckys2000gt in forum Audio, Security & Visual Electronics
    Last Post: 06-15-2010, 10:47 PM
  2. antenna location?
    By quadracer960 in forum General Tech Discussion
    Last Post: 03-29-2010, 12:35 PM
  3. Antenna wire issue.
    By pontiacgp759 in forum Audio, Security & Visual Electronics
    Last Post: 02-07-2010, 11:28 AM
  4. xm radio antenna help
    By hinkaj02 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2010, 04:36 PM
  5. Antenna... wtf?
    By Chris in forum Audio, Security & Visual Electronics
    Last Post: 04-29-2009, 05:02 PM
