Thread: Misfire in Cylinder 5
Results 1 to 15 of 15
  1. #1 Misfire in Cylinder 5
    SE Level Member 06gtSC's Avatar
    Lloydminster
    Hey everyone so im a little lost, as to my GP is saying that it has a misfire in cylinder 5, but i assumed it was the coil, i was wrong, bought a new one and installed and didnt fix the issue, so i returned it. any ideas as to what would cause this car to work fine until you step on the gas, then it hesitates and sputters, and shudders, then it continues to pick up speed while shuddering. Im really not to sure what may cause this, thanks in advance!
  2. #2 Re: Misfire in Cylinder 5
    Charles City, IA
    Replace the plugs and wires.
    SMGPFC Two Nipple General
  3. #3 Re: Misfire in Cylinder 5
    GT Level Member JbrownGTP's Avatar
    Colorado
    Also check your fuel injector on that cylinder
  4. #4 Re: Misfire in Cylinder 5
    Lloydminster
    i was thinking of the plugs and wires next, but the fuel injector is what scares me maybe to, i also dumped some fuel injector cleaner in it to see what may happen (hoax or not; worth a shot) It shudders and just doesnt seem right, can plugs and wires create that?
  5. #5 Re: Misfire in Cylinder 5
    Colorado
    Yes they can
    Fuel injectors aren't scary at all....in fact there pretty simple.
    When was the last time your plugs and wires were changed?
  6. #6 Re: Misfire in Cylinder 5
    Lloydminster
    i just got the car in october and i dont know when the last time was
  7. #7 Re: Misfire in Cylinder 5
    Colorado
    Ok then yeah start with the plugs and wires
    Its cheap and doesn't hurt to be done even if it's not the problem
    If that doesn't help we will try other things
  8. #8 Re: Misfire in Cylinder 5
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    lol, i just got my misfire figured out recently. i had a plug that kept fouling out fast as hell on that cylinder. turns out it was a coil.
    coil- 25
    new plug wires- 25
    copper core al 605's- 1.99 ea.
    the injectors are easy.
    depressurize the rails by pushing in on the rail shrader valve, it faces the front of the car
    you may need to get a fuel rail disconnect tool from napa, i had rubber fuel lines so i could bend the hoses pull the rails up with out disconnecting the lines
    10mm socket with about 5 or 6 inch 3/8 drive extension
    four nuts, one on each corner of the LIM and a 14mm on top of the of the SC
    pull the little retaining clips off of the injector plugs, 3 in front and 3 in back, with needle nose pliers
    pull the rail up and the injectors will come up with it, with the injector retaining clips that hold it on to the rail
    remove the injector that goes to the cylinder with the misfire and swap it with another one, just keep note of which one the 'supposed' bad one was swapped with to see if the missfire moved with the injector
    you can clean it out with some carb cleaner or some other type of degreaser, and the injector cleaner will also help
    put it all back together, fire it up, and scan. you dont have to put the injector plug clips back on yet, just push the plugs on and make sure they are on snug. see if the missfire moved with the injector, if so, bad injector.
    hope this helps, just did it about a week ago and dumped a can of seafoam into a full tank to run through the system. my missfire stayed
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  9. #9 Re: Misfire in Cylinder 5
    Follow the advice of these guys..and you'll be getting speeding tickets in no time.
  10. #10 Re: Misfire in Cylinder 5
    Lloydminster
    Thanks Guys! Appreciate all the help!
  11. #11 Re: Misfire in Cylinder 5
    Lloydminster
    i'll get around to doing it as soon as i can !
  12. #12 Re: Misfire in Cylinder 5
    Lloydminster
    That fixed it thanks guys!
  13. #13 Re: Misfire in Cylinder 5
    Would you believe that last night..I partially cured a transmission issue with a set of plugs.
  14. #14 Re: Misfire in Cylinder 5
    Colorado
    No problem good to hear its running smooth again!
  15. #15 Re: Misfire in Cylinder 5
    Lloydminster
    i'll be getting speeding tickets in no time!!!! and yes i thought my transmission was gone too from that, spark plugs can create a big issue!
  1. Cylinder #3 misfire
    By redgtp97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2013, 04:08 PM
  2. Cylinder Misfire!
    By AFBCamaro in forum Introductions/Noob Questions
    Last Post: 05-01-2010, 09:52 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
