Thread: A/C control
Results 1 to 13 of 13
  1. #1 A/C control
    SE Level Member UTfanatic80's Avatar
    Texas
    Ok, I have an 05 GTP and now that it's getting warmer I've been using the a/c more. The other day I tried to hit the recirculation function on the control panel but it doesn't blow any harder or colder?? Im kind of stuck on what to look for, any help would be great.
  2. #2 Re: A/C control
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I'm not sure that you actually have a problem...
    Recirc doesn't affect fan speed.
    Recirc 'might' provide cooler air when the cabin is already conditioned. Not if you get in the car and the interior is at 120F.
    Reciric literally just recirculates air opposed to drawing fresh outdoor air. It also uses the AC system.
  3. #3 Re: A/C control
    Quote Originally Posted by UTfanatic80 View Post
    it should blow harder when you hit the recirculation button, does the button light up still? it may be a fuse. i drive a regal mine lights up, not to sure about the grand prix
  4. #4 Re: A/C control
    Dec 2010
    Canada
    The fan speed increases when recirc is used?
  5. #5 Re: A/C control
    yes, mine does, well every car i ever owned did too
    it should only work when using the a/c
  6. #6 Re: A/C control
    Denver
    I don't think recirc affects fan speed - I just think it sounds louder as you're hearing exhaust and intake in the same cabin.
    You may also feel more airspeed as the incoming air via cabin has a shorter route (and less restricted flow).
    But, my guess is that if you meter the actual shaft RPM of the blower motor that it's completely unaffected my recirc toggling.
  7. #7 Re: A/C control
    GTP Level Member
    springfield IL
    Quote Originally Posted by mechguy View Post
    YES. On my 00 it does.
  8. #8 Re: A/C control
    Texas
    Yes it does still light up. I know it's suppose to blow a bit harder but it doesn't. Every car that i've ever had always did that. I'll have to check out the fuses and see if I see anything out of the norm. Thanks
  9. #9 Re: A/C control
    Denver
    Blowing harder isn't necessarily a sign of motor speed.
    AFAIK all recirc does, in ANY car, is activate a servo (vacuum or motor powered) to switch incoming air source via a valve/flap from ambient to cabin.
    It sounds louder (faster) and feels faster, but the motor rpm is unchanged.
  10. #10 Re: A/C control
    Pennsylvania, USA
    I have the same problem, given my A/C doesn't work due to a leak, but regardless recirculate doesn't change the sound of the blower what so ever, and it should if it works. If your fuse is ok, then look at this: Welcome To Sam's Web
    It's probably your hvac's recirculate actuator gone bad, apparently it's pretty common on our 04+ GP's, I'm going to take mine out today just to see if I can fix it myself.
    Oops, that's the homepage, here's a direct link so no one gets confused: http://home.comcast.net/~warren.family/AC.html
  11. #11 Re: A/C control
    if you take the glove box out you can see that door.
    hit the recirculation button and that door should close.
  12. #12 Re: A/C control
    GTP Level Member
    springfield IL
    Is this on the 97-03 models..??
  13. #13 Re: A/C control
    Quote Originally Posted by tc300 View Post
    yes, all cars really.
    its not that the fan speeds up, but when you hit recirculate that door closes, cutting off the fresh air, the fan is now in a sealed environment and blows harder.
    the recirculate button, is the same thing as setting a ford to max a/c.
  1. control arm over haul....
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 09-04-2011, 02:00 PM
  2. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  3. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  4. a/c control
    By stanggreg90 in forum General Tech Discussion
    Last Post: 07-27-2009, 10:07 PM
  5. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
