Thread: Fuel Injector O-Rings
Results 1 to 12 of 12
  1. #1 Fuel Injector O-Rings
    Dec 2010
    Lancaster, OH
    I just did LIM gaskets and figured I would install new o-rings on the injectors since the car has quite a few miles on it. I got 5 of the injectors completed but on the last one, the fiber washer on the bottom of the injector cracked while installing the new o-ring. Do I need to replace the injector? Does it have to have it or is it just there to keep the o-ring on the bottom? Thanks.
  2. #2 Re: Fuel Injector O-Rings
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    doesnt matter, Just go without it. Infact the upgrade size injectors(IE 42's, 60's and 80's) dont even have them.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Fuel Injector O-Rings
    Dec 2010
    Lancaster, OH
    Quote Originally Posted by 01gpgt01 View Post
    That's what I was hoping to hear! Thanks!
  4. #4 Re: Fuel Injector O-Rings
    hanover park, IL
    Doesn't that clip stop the oring from getting sucked into the engine? Mine cracked and I just replaced the injector.
  5. #5 Re: Fuel Injector O-Rings
    Quote Originally Posted by vincegpking View Post
    not really, just gives it a place to sit. however, there are already grooves there for the injector. the boss for the injector isnt big enough to allow the o-ring through unless you jammed it through on purpose.
  6. #6 Re: Fuel Injector O-Rings
    hanover park, IL
    Good to know now lol. I learned the hard way to take a razor blade and slice the old one off. The new one is much more plyable and should flex enough to get on.
  7. #7 Re: Fuel Injector O-Rings
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    ya the new ones roll on pretty much. get one side started, hold it in place, and push the rest of the o ring over that disk thingy, done
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  8. #8 Re: Fuel Injector O-Rings
    Dec 2010
    Lancaster, OH
    Yep. The first 5 injectors went great but the last one must have been cracked before I started because as soon as I put the new o-ring on it and started rolling, it snapped in half.
  9. #9 Re: Fuel Injector O-Rings
    The only thing that does is hold the ring on the injector so that when you pull the rail, they come up. Without that, you will typically need to pick the ring off the head. Not a problem at all.
  10. #10 Re: Fuel Injector O-Rings
    Nov 2010
    south east AZ
    oh you also want to put some type of oil on the new rings to help them seal better, like wd-40 or motor oil. Don't need a lot just enough to cover the oil side of the rings
    01 T/A WS6-SOLD
  11. #11 Re: Fuel Injector O-Rings
    Dec 2010
    Lancaster, OH
    Used a dab of WD-40 and they went seated just fine and no leaks. The car started back up for the first time in months. Now back to chasing the overheating demon.
  12. #12 Re: Fuel Injector O-Rings
    I keep a tube of vasoline in the toolbox goop drawer for o-rings. WD40 tends to eat rubber stuff.
    Plus..you should see the looks I get when people are looking for tools and find it.
  1. Which fuel injector?? is there a difference?
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 09:55 PM
  2. Fuel Line O rings
    By 4boostin in forum General Tech Discussion
    Last Post: 05-25-2010, 09:39 PM
  3. Fuel Lines O rings
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-05-2010, 08:45 PM
  4. Injector 0-Rings
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2010, 08:55 AM
  5. Should I replace the injector o-rings?
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2009, 11:16 PM
