Thread: Fuel sender - need to replace?
Results 1 to 3 of 3
  1. #1 Fuel sender - need to replace?
    SE Level Member Skrappi69's Avatar
    USA
    99 Grand Prix 3.8 no super turbo flux capacitor.
    Fuel gauge starts at full regardless of what's in the tank then creeps down to empty. Is this something with the gauge or is it the sending unit at the tank? I hope not the unit in the tank because the fuel pump and sending unit are one piece. Best price I found was $275 at Napa.
    I did find the ACDelco part that is just the float and rheostat for around $120 (depending on where you look). Would that be an option?
    Any advice or insight on this?
    Thanks!
  2. #2 Re: Fuel sender - need to replace?
    GT Level Member Deviq's Avatar
    SE WI
    This post should help ya out.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  3. #3 Re: Fuel sender - need to replace?
    SE Level Member UTfanatic80's Avatar
    Texas
    Actually the best solution I have found for my same problem was ebay. I found just the sending unit by itself for only $20 bucks. Hopefully this link will show up......Good luck!
    New Fuel Level Sensor (Sending Unit) - eBay (item 130502722274 end time Apr-27-11 14:44:01 PDT)
  1. I need to replace the fuel pump assembly, need a little help!
    By Crcblonde1 in forum General Tech Discussion
    Last Post: 05-09-2010, 04:25 AM
  2. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  3. Hooked up a Fuel Pressure Sender (with pics)
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2008, 09:28 PM
  4. are fuel sender units compatible with other brand gauges?
    By fst in forum General Tech Discussion
    Last Post: 10-03-2008, 04:42 PM
  5. Oil Level Sender Thread
    By Speeder in forum Turbo
    Last Post: 01-08-2008, 09:25 PM
