So the dreaded 'won't come out of park' finally happened. Does anyone have a wiring diagram/schematic for the park lock solenoid? I want to put some power to it and confirm it is the solenoid. The ignition switch works just fine--key always comes out (after putting it back in park), it doesn't lock up, and everything else seems to work fine. When I push the shifter button I do hear a clicking in the steering column, so I think that solenoid is working, but I have to push the shift lock override button on the console to get out of park. It is getting annoying, and I actually just zip tied the override button so I can shift without pressing the button every time, but I want to get it fixed. Anyone have a pinout or know which wire I need to put power on to test the solenoid? I am also losing power when I press the brake pedal (as it should), so that switch is working. The BTSI fuse is also good and making contact.
Also, anyone have any luck finding just the solenoid? The st(d)ealer wants to sell the whole shifter assembly for about $300.
