Thread: sd header help
Results 1 to 20 of 24
  1. #1 sd header help
    SE Level Member jerrysalley's Avatar
    Jun 2010
    somerset, pa
    i got speed daddy headers. i started installing them today but ran into a problem. i got manifolds off but i cant seem to get the rear header to go down in. i have front two mounts off n ratcheted the engine back as far as the ratches will go. so the question is why cant i get the rear header to go down in?
    thank u in advance for any help u can tell me.
    [/SIGPIC]99 GTP.
  2. #2 Re: sd header help
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    it took me a hour and a half to wiggle it just gotta keep wigglin another thing i had to do was remove the trans dipstick make sure the engine is as far forward as possible other than that keep wigglin
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  3. #3 Re: sd header help
    Donating Users gtp239's Avatar
    ft myers fl
    I think i pulled the map bracket off and the egr bracket. you have to put the rear on first or you cant get the engine far enough forward .
    also seems like common sense but you have to do it from the top and drop the down pipe in first.
    i then had some one help me wiggle it into place
    1998 gtp fwi, sd headers, overkill,3.4, poly mounts,p&psc
  4. #4 Re: sd header help
    lol ya make sure the front header is off i had a ratching strap tied to the snout and had the engine as far forward as possible than wiggle wiggle wiggle wiggle wiggle wiggle
    SMGPFC #77
  5. #5 Re: sd header help
    Minnesota
    I think I used a broomstick or like a shovel to pry it in there lol
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  6. #6 Re: sd header help
    Jun 2010
    somerset, pa
    i dont have the front on. its strapped forward. we wiggled n pried for 3 hrs n no success. would it help if put it on jack stands instead of ramps?
    [/SIGPIC]99 GTP.
  7. #7 Re: sd header help
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you gotta come in from the drivers side. You cant get it over the V/C
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: sd header help
    Jun 2010
    somerset, pa
    i can get it in but seems like firewall is stopping me from putn it down hole way
    [/SIGPIC]99 GTP.
  9. #9 Re: sd header help
    GT Level Member mkyota1's Avatar
    Daytona, florida
    I dropped the back of the cradle down a little and it slid right in from below. Just support the car just behind the cradle with jackstands, put jack at rear of cradle, then remove rear two cradle bolts and slowly lower jack. It should go right in.
  10. #10 Re: sd header help
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    way too much effort for the cradle thing. i ran into this very same problem when i did mine last week. someone mentioned to take out the trans dip stick. it is bolted to the trans with an 8 or 10mm socket and it pulls out. just wiggle the thing in from the drivers side, and ya the k member might get in the way. just gotta slowly maneuver it in there, itll go. the front is also gunna be a pain, just kinda twist that one in. i had a huge problem with the crossover going together with the two headers. i would get one side on but the other side wouldnt go together. i ended up ratchet strapping the rear driver side of the header and pulled it onto the crossover.
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  11. #11 Re: sd header help
    GTX Level Member colindunn's Avatar
    Aurora, IL
    rock that engine ALL the way forward. the smallest amount will make the biggest difference. then just make yourself and take the rear valve cover off, put a towel over it, and hit it down there. worked for me. wish i just did that first rather than messing around forever trying to figure it out.
  12. #12 Re: sd header help
    I've installed nearly every type of header on the market. For me removing two subframe bolts and being done in 20 minutes with the rear header is the best way to go. Doing the dipstick in the car loses trans fluid, makes a mess etc. My suggestion is lower the subframe.
    As for getting SD's together. This is a series of light taps with a rubber mallet while tightening the front up. Takes almost no time and is done.
    Average set of headers takes me about 2-3 hours complete
  13. #13 Re: sd header help
    Jun 2010
    somerset, pa
    thanks every1. im goin out now to try all the suggestions. wish me luck!
    [/SIGPIC]99 GTP.
  14. #14 Re: sd header help
    Daytona, florida
    Dropping the rear subframe sounds like it would be a big job but it really is two bolts and lower the jack. Its that easy. Good luck.
  15. #15 Re: sd header help
    Jun 2010
    somerset, pa
    well i tried everything and dropping the cradle worked best. took 20 min compared to 3 hrs tryn to wiggle it down in! thank u every1. but now the top sensor is way to short to plug in. wat did u do about this?
    [/SIGPIC]99 GTP.
  16. #16 Re: sd header help
    Charles City, IA
    Use an 02 sensor extension harness.
    SMGPFC Two Nipple General
  17. #17 Re: sd header help
    Jun 2010
    somerset, pa
    i dont have one of them. i didnt know i needed anything else
    [/SIGPIC]99 GTP.
  18. #18 Re: sd header help
    Charles City, IA
    It says you do in the header and mainfold thread, If you can solder you can make your own by extending the engine side of the harness.
  19. #19 Re: sd header help
    Jun 2010
    somerset, pa
    o ok ill try that then
    [/SIGPIC]99 GTP.
  20. #20 Re: sd header help
    Hagerstown,Md
    I wouldnt solder anything on 02's Its to sensitive. Just get a plug and play extension
  1. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  2. Rear header
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 12:54 PM
  3. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  4. new header brand????
    Last Post: 04-29-2009, 04:01 PM
  5. TOG Header Question...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 01:00 AM
