Thread: Windshield Wiper Motor
Results 1 to 13 of 13
  1. #1 Windshield Wiper Motor
    SE Level Member gpgt98's Avatar
    Jul 2010
    Michigan
    When I got the car back in the summer, the wipers only worked on the high setting and when I turned them off they would stop in the middle of the window. Well I went to the junk yard and got another motor. This one still only works in the high setting and I have to time it just right when I shut them off for them to stop in the normal position. Could it be a bad motor or maybe the wiper switch is messed up?
  2. #2 Re: Windshield Wiper Motor
    When you got the replacement. Did you get just the motor or the motor and electronic module that should be part of the motor assembly?
  3. #3 Re: Windshield Wiper Motor
    Jul 2010
    Michigan
    Sorry should have mentioned that, I got the whole assembly
  4. #4 Re: Windshield Wiper Motor
    Ok, before you put the arms on.. I think you are supposed to cycle it to ensure it's timed properly. You probably did that too right?
  5. #5 Re: Windshield Wiper Motor
    Jul 2010
    Michigan
    Yeah I did that. When they actually go down in the correct position, they are sitting nicely on the stoppers. But they only work on the high setting and if I click it down to low or any of the delays, it will stop wherever they are at on the windshield..
  6. #6 Re: Windshield Wiper Motor
    Oskaloosa
    Did you get anything figured out on this? My 05' is doing the exact same thing, I figured it was the module on the motor. Checking the site to see if that is the case or not.
  7. #7 Re: Windshield Wiper Motor
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Are you sure the actual wiper is sitting on the spline shaft correctly and the nut is not loose?
  8. #8 Re: Windshield Wiper Motor
    Oskaloosa
    There not lose. I check that first, and they work just fine on high. Just spurratic or not at all on low or itermittent.
  9. #9 Re: Windshield Wiper Motor
    Oct 2011
    Reading PA
    Strange... its a basic setup... assembly attached to a motor to spin the shafts.. If it were me, id just go to a junkyard and pull both the motor and assembly for the wipers.. Im sure together it would be less then if you just bought a new motor or assembly anywhere. But there is always that slight chance that it may be an electrical issue..
  10. #10 Re: Windshield Wiper Motor
    Jul 2010
    Michigan
    Holy old thread batman..
    But I just replaced the whole motor and linkage and it fixed itself after that
  11. #11 Re: Windshield Wiper Motor
    Topeka, KS
    Motor Pulse Board causes this issue. I need to replace mine.
    If they stick straight up after shutting them off its the metal tab that the motor parks on. It needs bent up.
  12. #12 Re: Windshield Wiper Motor
    Oct 2011
    Reading PA
    Quote Originally Posted by gpgt98 View Post
    Haha i just saw the original date on this post.... Glad your still not having the issue since it was 8 months ago.
  13. #13 Re: Windshield Wiper Motor
    Jan 2009
    Long Island
    mine is parking in the middle @ 12 O'clock.
    "If they stick straight up after shutting them off its the metal tab that the motor parks on. It needs bent up."
    IS this located inside of the Motor Pulse Board?
    Will this fix it??
  1. Windshield Wiper Help
    By Liquifire in forum General Tech Discussion
    Last Post: 01-17-2010, 03:19 PM
  2. Windshield Wiper Issue..
    By EarlyGTDriver in forum General Tech Discussion
    Last Post: 08-26-2009, 05:00 PM
  3. Windshield Wiper Pump
    By sirschuster in forum General Tech Discussion
    Last Post: 04-21-2009, 05:50 PM
  4. Windshield Wiper Question
    By BADAZGTP in forum General Tech Discussion
    Last Post: 08-20-2008, 10:56 PM
  5. windshield wiper help
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 02:48 PM
